Can you charge a Li Ion battery bank with a Outback FM 80?
RanchoPacifico
Registered Users Posts: 7 ✭✭
I have agm batteries now but have a chance to pick up a lifepo battery bank at a very reasonable price. It is a LiMax BMT sr5000r LifePo4 battery at 48v. My existing system is 2 Outback VFX 3648 inverters, Fm80 charge controller and 12-190 watt solar panels on solar trackers, and 20-12v-100ah AGM batteries. Ideally I"d like to just remove the AGM batteries and install the LifPo's but I am not naive enough to believe that that is possible. So what modifications will I have to do to use the Li batteries with the fm80 other than program in new charge parameters? The Li battery packs have their own balancing system and charge controller built in. Here is a link to the system:
https://manualzz.com/doc/23730051/user-s-manual---solarmax-technology
Thanks in advance for any help.
Off grid in northern Baja, 2- vfx3648, FM80, 2280 w pv array pole mounted with solar trackers, 300ah LiFepo4 battery bank, Kubota 6.5kw Diesel gen.
It is possible given the controllers and inverter are programmable, although not directly related to the LiFePo4 batteries you may have, there are recommended settings from other manufacturers that can be used as a guide. Using the information provided by SimpliPhi batteries for use with Schneider equipment, for example I was able to come up with an approximate set of values for a DIY bank that have been working well for the past 2.5 years.
Simpliphi also has similar settings for Outback equipment which could be used as a guide to establish a starting point, a Web search will provide pdf links, it's actually very simple, contrary to popular belief, way easier than lead acid as long as the fundementalsare followed. Personally I would highly recommend studying the chemistry before making a switch, focusing on the limitations, especially low temperature, outside of freezing environments they make perfect sense.
If you are serious about making the change and freezing temperatures are not a hurdle to be overcome, I'm willing to offer guidance based on experience. Personally I'm in the tropics where low temperature is a non issue, as I've no idea where you are located it's impossible to comment without this information.
Thanks for the offer to help, I would appreciate that. I'm in northern Baja Mexico, at sea level so very little chance of freezing here. The battery bank seems to have the BMS built into cabinet, is 48v nominal, and rated at 5280wh. I will look on line for Simpliphi and see what I can come up with. Thanks again.Off grid in northern Baja, 2- vfx3648, FM80, 2280 w pv array pole mounted with solar trackers, 300ah LiFepo4 battery bank, Kubota 6.5kw Diesel gen.
- 234 Forum & Website
