Newbie off grid system help
moonshine82
Registered Users Posts: 5 ✭✭
Hi just starting a new off grid solar system and need some recommend products currently I have 8 310 mono panels looking to purchase the right mppt controller and the correct inverter prob going to go with 4 lifepo4 batteries would love some recommends don’t want to drain or under utilize my panels
What will your system voltage be?
Where are you located?
Do you know your daily loads?
Do you have certain expectations? Is the grid available?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Also, while LiFePO4 batteries are just about the ideal battery (long life, store at any reasonable state of charge, no maintenance, light weight, compact, etc.)... They do have a few weak spots (one of which they are not cheap).
They do not like being over/under charged and do not like running much below 40F--And should not be operated below 32F--And many Lid Ion batteries have or are operated with a Battery Management System (BMS) to ensure that the individual cells are within voltage/temperature/current specifications, and can have an emergency disconnect if the operations will damage the cells. As always check the battery mfg specifications for details.
And--When picking equipment--There are some battery BMS that will integrate/talk with Charge Controllers and AC Inverters so that they will help the Li Ion batteries operate within their specifications.
Do not purchase anything until you have a good understanding of your loads, environmental requirements, and how all of the equipment will play together.
Probably the most significant is your location. FLA batteries do great in the cold so long as they are charged. I'd hate to buy Lithium ion batteries at great expense only to find that they won't work in your climate.Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
With the low price of panels, you want to over panel a bit, and calculate ACTUAL expected harvest vs STC spec. And there will be days you don't have perfect sun and loose power.
I won’t be below 40f I’m on the NorCal coast, grid is not available need to know what mppt To get I’ll be getting lifepo4 batts just need to know wht charge controller and inverter to get that will work for these panels will be doing a 24v config
moonshine82 said:I won’t be below 40f I’m on the NorCal coast, grid is not available need to know what mppt To get I’ll be getting lifepo4 batts just need to know what charge controller and inverter to get that will work for these panels will be doing a 24v configmoonshine82 said:don’t want to drain or under utilize my panels
MidNite Solar - Classic Sizing Tool.
Was thinking about one of these
Anyone have recommend in a correct inverter? -
Victron 250/85 doesn't list any certifications. California is a highly regulated state, check to see if yu need UL1741 equipment.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
moonshine82 said:Anyone have recommend in a correct inverter?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Still need to get the specs on my Appliances etc and do the actual math on my loads... but for a ball park I’ll be running a chest freezer, 24 cu ft fridge, Edison and led lighting on a 2 bdrm cabin , washer and dryer (heating elements are propane ) 2 lg TVs some phone charging and laptop charging
moonshine82 said:Still need to get the specs on my Appliances etc and do the actual math on my loads... but for a ball park I’ll be running a chest freezer, 24 cu ft fridge, Edison and led lighting on a 2 bdrm cabin , washer and dryer (heating elements are propane ) 2 lg TVs some phone charging and laptop charging
If you're going with a Victron CC you should consider a Victron inverter.
Photowhit said:Victron 250/85 doesn't list any certifications. California is a highly regulated state, check to see if yu need UL1741 equipment.
littleharbor2 said:If you're going with a Victron CC you should consider a Victron inverter.
You may want to consider one of the 24V 3kVa Victron inverter models. You may need 2 depending on your loads and if you want split-phase 120/240 via 2x inverters or an autotransformer.
https://www.victronenergy.com/upload/documents/Datasheet-Multiplus-inverter-charger_2kVA-and-3kVA-120V-US-EN.pdf
If you don't want to go the charge controller route, you could always use a GT inverter combined with a Victron battery inverter. In that case, you'll get away with higher voltage strings and less wiring. Several other advantages as well. -
jakobw said:Photowhit said:Victron 250/85 doesn't list any certifications. California is a highly regulated state, check to see if yu need UL1741 equipment.
I was not trying to mislead anybody, I went to their spec sheet and it's void of any certifications.
Photowhit said:jakobw said:Photowhit said:Victron 250/85 doesn't list any certifications. California is a highly regulated state, check to see if yu need UL1741 equipment.
I was not trying to mislead anybody, I went to their spec sheet and it's void of any certifications. -
It is absolutely critical that you define the load and their duration to get an accurate daily load estimate...then ad 30-50% for head room. Are tiny cabin, with propane fridge, no tv, no WD, only LED lighting, small water pump, we use ~500-1000 kWh/day day in and day out.
If you don’t do that you will be doomed to make an expensive mistake. All calcs should be derived from the loading.
- 628 Discussion Forums/Café
