Can i use a POS+ ground rover pg 60a and NEG- ground rover 60a controller on the same battery bank
MEK1954
Registered Users Posts: 23 ✭✭
Can i use a positive ground rover pg 60a and negative ground rover 60a controller on the same battery bank
Yes, for an exciting half a second, then things burn up.
So, actually, no. Sorry. Draw a sketch, you will be wiring a dead short across your battery when you connect the ground cable to both the + and the - terminals. Boom !!
You do understand that a + ground does not mean the cable has to be grounded to a chassis you would still connect + to + and - to -. and in theory they should work if there is no electrical connection between the controller frames.
- 230 Forum & Website
