I don't know which provider to choose
pikaap
Registered Users Posts: 1 ✭
I don't know a lot about solar power, but we have decided to build a solar panel at home.
My father and I have narrowed it down to two providers. I'm not sure what I should be careful for, so I ask you for help.
This is the data I thought was most relevant. I kindly ask for you help.
Thank you!
Pika
COMPANY |
PRICE |
POWER |
PANELS |
WARRANTY (panel) |
Sončni sistemi |
15.054,19€ |
22,14 kWp |
ODA 410-36-MH (OSDA Solar) |
15 years |
JB Energija |
14.912,00€ |
22,20 kWp |
TSM-DE08M(II) (THE HONEY M-TRINA SOLAR) |
25 years (power warranty) |
Thank you!
Pika
Welcome to the forum
Solar companies come and go, therefore it's a question of who will be around to provide the warranty......probably neither in the 15-25 year future, the lower cost with the higher panel warranty would be the obvious initial choice, just don't expect them to be around in the unlikely event the panels would fail to perform to their expected lifespan.
The electronics needed, wether off grid or grid tied, would likely have issues way before the panels so it's important to select those with robust support and warranty coverage, the panels are of secondary concern......in my opinion.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
