MT50 SOLAR
filbo
Registered Users Posts: 1 ✭
Hi, just gotmy first campervan and trying to sus the MT50 solar thingy. The icon on the left always shows nighttime. I cant seem to work out why it won't show daytime. Any ideas. I also had new battery fitted so not sure if that affected anything. Any kind of help would be great. Also, the load icon has lines rou d it, should these be off when not hooked up?
Sounds like you might have the polarity reversed or a very poor connection. Check with a digital voltage meter.
Not sure if I'm following you exactly, but if you replaced the battery, it's likely you need to disconnect the solar array and first connect the battery to establish the system voltage. Before you connect the solar array.filbo said:Hi, just gotmy first campervan and trying to sus the MT50 solar thingy. The icon on the left always shows nighttime. I cant seem to work out why it won't show daytime. Any ideas. I also had new battery fitted so not sure if that affected anything. Any kind of help would be great. Also, the load icon has lines rou d it, should these be off when not hooked up?Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
Hi
i did this and got the same result. Fixed it by disconnecting everything, then connecting battery, then panel, then load in that order.Dimspark
