MT50 SOLAR
Hi, just gotmy first campervan and trying to sus the MT50 solar thingy. The icon on the left always shows nighttime. I cant seem to work out why it won't show daytime. Any ideas. I also had new battery fitted so not sure if that affected anything. Any kind of help would be great. Also, the load icon has lines rou d it, should these be off when not hooked up?
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,198 ✭✭✭✭✭
    Sounds like you might have the polarity reversed or a very poor connection. Check with a digital voltage meter.
  • Photowhit
    Not sure if I'm following you exactly, but if you replaced the battery, it's likely you need to disconnect the solar array and first connect the battery to establish the system voltage. Before you connect the solar array.
  • Dimspark
    Dimspark Registered Users Posts: 1
    Hi
    i did this and got the same result. Fixed it by disconnecting everything, then connecting battery, then panel, then load in that order.
    Dimspark
