missing mc4 connectors
alcatel99
alcatel99 Registered Users Posts: 31 ✭✭
I have just been to visit a neighbour 18 miles away and he showed me his new solar system which appears to be all good with well known products only thing i did not understand was he did not have any mc4 connectors on his panels or on extended cables he just has them soldered and shrink wrapped he says he was told that the mc4s can reduce power
i have never heard of this, his system is working good and he seems happy ,so has anyone ever heard of this.
    Damaged or improperly handled MC4 connectors can reduce power.   And many folks in ignorance, have likely damaged them by connecting / disconnecting under load, leaving unconnected and exposed to weather, or rough handling and breaking the weathertight seals.
    Soldered and heat shrink works too, but becomes clumsy when repair/inspection/diagnosis is needed.
    Photowhit Solar Expert Posts: 6,024 ✭✭✭✭✭
    Soldered and not crimped connections are not code compliant! Must be crimped first and still with wires subject to even gentle movement the solder creates a fulcrum point for connections to fail.
    There is a very slim chance to have problems with MC4 connectors unless, and to a degree even with, poor handling.
