Help Building EGP1000W Inverter
Licentia
Registered Users Posts: 2
I am trying to build a 1000w DC to AC110 inverter using a EGP1000W circuit board:
However, I was wondering what size capacitors I should use for C1, C2, C3, C9, C5, C7 and what size inductor I should use at L1, as it is not mentioned in the schematic:
Re: Help Building EGP1000W Inverter
It appears that the information is here:
http://www.egmicro.com/download/EG8010_SPWM_V2_2.pdf ,
http://www.egmicro.com/download/EGP1000W_manual_20110509.pdf ,
http://www.egmicro.com/download/EGS001_datasheet_v1_2.pdf ,
But the website is down (missing in action?).
Ebay links do not usually last long, but you may try contacting/researching through here:
http://www.ebay.com/itm/1x-EGP1000W-Pure-Sine-Wave-Inverter-Power-Board-PCB-Bare-Board-New-/171198645951
Re: Help Building EGP1000W InverterIt appears that the information is here:
I've seen those links but the manual is in Chinese. I've tried using Google to translate some of it and I get,There are three electrolytic capacitors (C1, C2, C3) and two decoupling capacitors (C14, C15) on-board power supply bus. Capacitor voltage value Must be selected according to the power supply voltage. Such as working in high-frequency mode, the power supply bus voltage (330V ~ 400V), the select voltage is 450V. If in-frequency mode, the power bus voltage power 48V, select the capacitor voltage should 63V. Electrolytic capacitor according to the actual system power capacity Choose generally should be greater than the high-frequency mode 47uF, power frequency mode should be greater than 470uF. 0.1uF decoupling capacitor generally choose the CBB capacitor voltage must Greater than the power supply bus voltage. If the capacitor voltage is less than the power supply bus voltage, capacitance may cause an explosion hazard!
So if I'm working in-frequency mode, and not high-frequency mode, the capacitor voltage rating should be 63v or higher? What about the uf rating? I can't find any information in the manual about C9 C5 and C7, so I'm not sure which sizes to use on these. Here's another photo I've found but it doesn't say anything about C9, C5, and C7, which are located on the bottom.
Attachment not found. -
I have another problem with this board. It needs 400v DC at P3 ??? haw can I get 400v from 12v batteries? -
I don't think anyone can really help with the details on this board.
Here is a quick description on how AC inverter work and get high voltage from 12 VDC:
https://en.wikipedia.org/wiki/Power_inverter
There are other methods to get high voltage too...
Hi all,
seems I am new here, all of your post are old ones, hoping i am not too late to give any comment here.
well, EGS002 and EGS003 from EGMicro.com are so fantastic module, you just need to follow it's simple diagram or you may buy any PCB which use EGS module, and it works good.
well, i use the low frequency one, but some of my friends did the high frequency and same work good too.
good luck to all of you.
God Bless.
This thread may help.
However, I seriously doubt a neophyte taking a high power circuit, attempting design on the fly, and having success.
Heathkit in years past, could do it, with a complete kit and well designed circuits and construction manual.
https://forum.solar-electric.com/discussion/354711/2nd-edition-6kw-ozinverter-build-book-manual-pcbs
- 234 Forum & Website
