Wire Type for Inverter AC output to Power Center Input
gregbyst
Registered Users Posts: 38 ✭✭
I am going to be wiring my inverter into my trailer soon and am wondering what type of cable to get. I heard that solid core Romex will do. Should I use 10/3?
- 4 of the 12 volt, 200ah AGM renogy batteries (I sent a screenshot of the specs above).
- 150/60 MPPT Epever Charge Controller
- 3000 watt (9000 peak) inverter/charger/auto-transfer switch
- PV array of 6 260 watt, 30.7 Vmpp, 8.5 Impp.
- Battery Shunt Monitor (https://www.amazon.com/gp/product/B07FGFFHC6/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1)
Also, I live in a fifth wheel!
It would be helpful if more information were provided. Size of the combined load in amps or watts, size battery bank, and the size of the inverter.
