XWPro firmware and Gateway simultaneous update firmware for grid and AC couple issues.
Over the weekend new firmware was made available on the Schneider site for some bug repairs and improvements. For Offgrid applications, I would wait unless your issue is listed below. This was a simultaneous release and so both firmware need to be done. As always with firmware on an inverter, insure that your power source is not the inverter being updated. It will cycle AC out.
    Dave Angelini Solar Expert Posts: 6,950 ✭✭✭✭✭✭
    Where can I download the firmware?
    You can download the latest firmware (zip file) from the below links. Please scroll down to Downloads and click on Firmware.
    Note: There are required changes to the XW Pro firmware upgrade instructions. Once downloaded, please unzip and read the step-by-step guide, "READ ME FIRST_XWPro Amended Firmware Upgrade Procedure_v1" before updating the firmware.
    Is this the Gateway firmware fix that lets you recover a bricked device ?
    No Mike, the recovery bootloader was in 1.07 and later. How is the smoke up there? Still pretty bad down here. They closed Yosemite.
    We are getting wind from different directions, and so the smoke varys quite a bit., last night was  7 on the airnow gov site, day before it was +300 (really bad)
    Sorry to hear that Mike. You inside a cocoon I hope. We just leave the heat pump on at night and pressurize the house to insure it stays out. We run a merv 13 in a box fan to keep the air good from opening and closing doors. Nasty business in the West this year, more than I expected for sure. Those with home insurance are really going to shell it out. They know there are not enough fire people.
     Our local weather is weird because the Sierra mountains make its own up slope day wind and downslope at night.The north westerlies are too weak down here and the normal inversion layer of September is just no bueno.
