Whisper 200 charge controller
isljc
Registered Users Posts: 1 ✭
I have a whisper 200 wind turbine. I disconnected the turbine from the battery bank and when I reconnected it it didn't work. It had no lights on on the charge controller and it didn't charge. I have power from the battery and the turbine at the controller. I have heard about the microprocessor latching up . Could this be the problem and if so how do I unlatch it
Don't know, but my suggestion...First stop the blades from turning (tie with rope or no wind day).Disconcert the battery power to turbine.Wait 5 minutes.Reconnect battery power.Let blades spin.Have you checked the brushes in the use bearing area (12vdc is getting through brush assembly to circuit board)?BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
I looking for a circuit board diagram for my whisper 200 charge controller.
