Need help understanding my boat 2 batteries - solar and wind powered electrical system
Felinethecat
Registered Users Posts: 2 ✭
Hi there,
There
are 2 batteries connected together, one for starting outboards and a
200AMP deep cycle one for the house, a solar panel and a wind turbine
(not functioning until I'll give it maintenance and replace blades).
Problem is for now that it seems even on a sunny day the solar panel
won't charge the house battery.
I haven't been able to try it while
running the 2 outboards.
I know that the
installation has been done few years ago by a professional (that didn't
label much things that I can understand) and seems to be all in good condition from my low
expertise level.
The solar panel is at least 10 years old but I have limited information as for everything.. It does look in good condition though (unlike the wind turbine).
On the DC METER, I can read
around 14.5-14.4V for both start and house battery when sunny without
anything turned on, also a discharge of 1.3-1.7A in those conditions,
and a charge of 0 no matter what I do playing with the different
buttons/settings available.
On the second picture, the left Amp
indicator is "ticking" hard when the sun hits and I have nothing on, but
still no power goes to my house battery.
I believe the second one showing -+30 amps could be wind turbine related?
Also
the starting battery shows a green dot saying it should be fully charged. The DC meter only gives me the house battery current
capacity. It does stay constant over days of everything turned off.
The last pictured item is in stand by no matter what, so I guessed this one could be going with the outboards running?
If
I turn on the water pump/lights or fridge I read a reduced voltage on
the DC Meter for both starting and house battery (believe they are
connected together, and heard from old owner that start battery should "overflow" when full to charge the house battery...)
I'm really keen on
learning how all these systems work and will be very thanksfull to anyone
taking the time to read me and give some advice!
Cheers
It is possible that there is a eco charger on your start battery, what this dose is when your start to get up in voltage on the start battery it switches over automatically to charge your house bank , when it stop charging it separates the 2 nd bank.I all ways used 3 150 ah gell battery’s and used them as one big bank .
Pic 1 could be your eco charger ?You could spin your win generator with a drill if you tap up the shank .The solar controller dose not seam to have all the wires in place ?All my morning star units have +- from the solar panel and to the battery unless I just can’t see it in the pic.How large is you solar panel what size out boards do you have , they don’t Usually put out A lot of power
You need to figure out what battery is bank one and bank two , I’m thinking your start battery is batt# 2 .And you need more power to flip the relay , maybe try hooking a regular 12v charger up and see if the power feed thru to the second battery .Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar . -
Trying to understand someone else's design without a wiring diagram is probably one of the most challenging tasks, my inclination would be to remove everything and start from scratch. Understandably that's me, so assuming everything is intact and was working previously the best approach would be to evaluate the components, there seems to be corrosion on many of the terminals, I would work on cleaning them for starters. The house battery appears to be older than the start battery, try looking for a date of manufacture, there seems to be one near the negative terminal but I can't zoom in enough and a wire is obscuring the digits.
An older battery, can by voltage alone, appear to be fully charged but actually has little capacity, load testing would establish this. There appears to be a selective relay between the start and house battery, which is common on boats along with RV applications so as not to drain the starter battery with house loads, personally I believe it's best to keep both systems divorced from on another to eliminate uncertainty.
The inclusion of wind power only complicates matters, attempting to reverse engineer someone else's Frankenstein wouldn't be something I would not be willing tackle, especially without being on site, for this reason I suggest starting from scratch and keeping records including wiring diagrams so you remember what it is you did.
As I have no idea of your personal level of experience, it's difficult to offer suggestions other than those outlined, what may have made sense to the original installer dosent nessersary translate to others.
wellbuilt said:The solar controller dose not seam to have all the wires in place ?How large is you solar panel what size out boards do you have , they don’t Usually put out A lot of power
You need to figure out what battery is bank one and bank two , I’m thinking your start battery is batt# 2 .And you need more power to flip the relay , maybe try hooking a regular 12v charger up and see if the power feed thru to the second battery .Solar panel is about 1sq meter, I found out taking down the wind turbine yesterday that it was manufactured in 2004, I believe the solar should be aged around the same. Outboards are 2x 9.9 yamahas, trying them tomorrow see if it changes my input.Sorry not very clear on picture but the morningstar does have 2 wires on the battery terminal, just none on the load.Yeah the black champion battery is #2.I'll try with a charger see what happens, thanks for suggestion!mcgivor said:Trying to understand someone else's design without a wiring diagram is probably one of the most challenging tasks, my inclination would be to remove everything and start from scratch. Understandably that's me, so assuming everything is intact and was working previously the best approach would be to evaluate the components, there seems to be corrosion on many of the terminals, I would work on cleaning them for starters. The house battery appears to be older than the start battery, try looking for a date of manufacture, there seems to be one near the negative terminal but I can't zoom in enough and a wire is obscuring the digits.
The one component that shows corrosion is that galvanic isolated on pic #5 (DC-DC converter from my researchs?) everything else is under the bench and seems totally fine. I haven't shown what I believe is the wind turbine controller and a 50Amp circuit breaker that should be related to it.I'll try find that house battery date of manufacture, and find out how to test it under load. See my new parameters with engines running and wind turbine on.Redoing the wirring is a bit frightenning right now, but if I come down to it by not solving my issue, should be a great challenge.
I find odd humor in the Galvanic Isolator being the piece of gear with corroded terminals.
And sadly, the wiring rats nest/tangle is about as bad as the contents of my junk wire box. The whole thing, since it's not working right, and nobody knows what the original intent / scheme was, is to redo the the thing. Sorry. That's the right way to fix it.
- 228 Forum & Website
- 618 Discussion Forums/Café
