Solar Panels more watt?
rmathers
Registered Users Posts: 3 ✭
Can I go from 100 watt (2) panels to 200 watt (2) on a 40 amp controller 12 volt battery?
YesIsland cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year.
100w @ 12 v = 8.3A, so 400w would only be 33A, so it would work. What's the Vmp voltage on the 200w panels ? if it's over 19V, you will not see the full 200w unless you use a MPPT controller
My 100w 12v Polycrystalline (Blueish coloured) panels produce 5.8A each. Coleman Branded Sunforce. Coleman Branded Sunforce 30A PWM Controller states Max 450w. It's never produced over 21As @ the Controller, using 4 Panels.
So going to a 40A Controller PWM (as I have) I plan adding 2 more panels to the array totaling 600w@12v -
Details do matter with solar... There are PWM (Pulse Width Modulation) inexpensive solar charge controllers, and there are MPPT (Maximum Power Point Tracking) more expensive controllers (there is a third type--PWM controller fraudulently labeled as MPPT).
PWM controllers typically have a solar array with Vmp~17.5 volt panels. Their maximum current is 4x Imp of the panel, or roughly (for example, a 600 Watt array on a PWM controller):- 600 Watt of panels (4x parallel connected) / 17.5 volts Vmp = 34.3 amps Imp array
If you have a MPPT type solar charge controller (typically more expensive than PWM)--The math is different, but MPPT controllers can "manage" their output current to rated current safely/reliably--So it is possible to "over-panel" an MPPT controller and have things work quite nicely. But the "math" (and array configuration) is different from PWM.
Sorry, it wasn't my question. I just replied with what I know that works.
I know that 400watts 12v can safely go to a 30A PWM Controller (450w actually in the Controllers Manual).
I know that Harvest @ the Controller with 400w 12v, is only 20A with wiring losses(2 runs of 12AWG wire, 25 and 30').
So I feel safe adding 2 more panels (100w each) to my 40A Controller totaling 600 watts, 12v PWM Controller.
So the answer to the Original Posters question is YES, 200w 12v to a 40A Controller is safe. With room to expand. PWM or MPPT Controller. Poly or Mono 12v Panels -
My hqst 30 amp pwm controller stated 450 watts @12 volts.
With 4 100 watt 5.3 imp panels on a cloudy morning and ~60 soc battery 40f temps.
Sun came out midday I was seeing 26 amps.
6.5 each from 5.3 imp x6 =39 amps.
So imo your taking a chance with 6 5.8 amp panels on a 40 amp pwm controller.2kw array 6 345 q cells make sky blue 60 cc
6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
