Solar Panels more watt?
                    rmathers
                    Registered Users Posts: 3 ✭
                    Can I go from 100 watt (2) panels to 200 watt (2) on a 40 amp controller 12 volt battery?
            YesIsland cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
            100w @ 12 v = 8.3A, so 400w would only be 33A, so it would work. What's the Vmp voltage on the 200w panels ? if it's over 19V, you will not see the full 200w unless you use a MPPT controller
            My 100w 12v Polycrystalline (Blueish coloured) panels produce 5.8A each. Coleman Branded Sunforce. Coleman Branded Sunforce 30A PWM Controller states Max 450w. It's never produced over 21As @ the Controller, using 4 Panels.
 So going to a 40A Controller PWM (as I have) I plan adding 2 more panels to the array totaling 600w@12v
            Details do matter with solar... There are PWM (Pulse Width Modulation) inexpensive solar charge controllers, and there are MPPT (Maximum Power Point Tracking) more expensive controllers (there is a third type--PWM controller fraudulently labeled as MPPT).
 PWM controllers typically have a solar array with Vmp~17.5 volt panels. Their maximum current is 4x Imp of the panel, or roughly (for example, a 600 Watt array on a PWM controller):- 600 Watt of panels (4x parallel connected) / 17.5 volts Vmp = 34.3 amps Imp array
 If you have a MPPT type solar charge controller (typically more expensive than PWM)--The math is different, but MPPT controllers can "manage" their output current to rated current safely/reliably--So it is possible to "over-panel" an MPPT controller and have things work quite nicely. But the "math" (and array configuration) is different from PWM.
            Sorry, it wasn't my question. I just replied with what I know that works.
 I know that 400watts 12v can safely go to a 30A PWM Controller (450w actually in the Controllers Manual).
 I know that Harvest @ the Controller with 400w 12v, is only 20A with wiring losses(2 runs of 12AWG wire, 25 and 30').
 So I feel safe adding 2 more panels (100w each) to my 40A Controller totaling 600 watts, 12v PWM Controller.
 So the answer to the Original Posters question is YES, 200w 12v to a 40A Controller is safe. With room to expand. PWM or MPPT Controller. Poly or Mono 12v Panels
            My hqst 30 amp pwm controller stated 450 watts @12 volts.
 With 4 100 watt 5.3 imp panels on a cloudy morning and ~60 soc battery 40f temps.
 Sun came out midday I was seeing 26 amps.
 6.5 each from 5.3 imp x6 =39 amps.
 So imo your taking a chance with 6 5.8 amp panels on a 40 amp pwm controller.2kw array 6 345 q cells make sky blue 60 cc
 6 230ah GC @36 volts
 18 amp accusense charger. 3650 champion
- 232 Forum & Website
