Self actuating or self resetting breakers
mrcc1
Registered Users Posts: 3 ✭
I normally use manually reset able breakers for the positive line from charge controller to battery.
Are there any pros and cons to using a Self actuating or self resetable breaker instead?
Pro: you don't have to chase it down to reset it
Con: if you get a fault and don't notice it right away, it will keep resetting till the battery is dead or the wire eventually overheats
- 230 Forum & Website
