Use a vfx 3648 control board in a gvfx 3648 inverter?
RanchoPacifico
Registered Users Posts: 7 ✭✭
The control board on my gvfx 3648 went out on me and a friend has a spare vfx 3648 control board that I can borrow. Does anyone here have actual experience with using a vfx control board in a gvfx inverter? I contacted Amos at Zonna and he said that the FET and AC boards are the same in the 2 inverters and he thought it should work fine. I'm in Baja and there aren't too many options to getting the correct part down here in a timely fashion. I'm offgrid and do not have a grid option either. My generator is getting some overtime use now.
Off grid in northern Baja, 2- vfx3648, FM80, 2280 w pv array pole mounted with solar trackers, 300ah LiFepo4 battery bank, Kubota 6.5kw Diesel gen.
Why not call Outback? Ask on their user forum? I could guess yes but there are model year changes and I would not want you to ruin your friends PCB. I will ask my installer buds. How much is gasoline on the baja? Back later if I hear anything."we go where power lines don't" Sierra Nevada mountain area
Got this back from a bud! Please keep me in mind if you need a system down there! Cheers! --Dave
"Yes will work fine.But no grid tie of course and won't stack""we go where power lines don't" Sierra Nevada mountain area
- 230 Forum & Website
