Used Solar Panels
1popeman
1popeman Registered Users, Users Awaiting Email Confirmation Posts: 1
Hi, I am here to ask questions about used solar panels. I was given 30 used solar panels. I know that solar panels have improved since these panels were made. I have tested the voltages on all of the panels and they are @ about 95% capacity.
Here is my question, since these panels work fine and they are free why not use them?
I also need to know what inverter to use. The array has a combined output of 7500 watts. They are KYOCERA KC167G panels.
I want to use these panels on a house on Kauai.
Any information is appreciated .
Tom
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,196 ✭✭✭✭✭
    Those are pretty old panels. Kyocera makes a great product though. Off grid they should be fine. If you are planning on a grid tie system, there may be problems with used equipment. You will not qualify for any Federal tax rebate.
    Photowhit Solar Expert Posts: 6,024 ✭✭✭✭✭
    They appear to be UL certified, shouldn't be any problem for any type of installation.
    Checking the panels by sticking a meter on them without a load, you are looking at the VOC numbers. I don't doubt that they are fine though. Looking at the numbers I would assume they are 48-54 cell panels. These were originally intended for grid tie, but work great off grid with MPPT type charge controllers.
    https://americas.kyocera.com/press-releases/press-releases_20150319386.htm
