Need Xantrex XW6048 older firmware
hvillegas1966
Registered Users Posts: 7 ✭✭
First time post and just registered to this forum.
Looking for little bit of help if anyone would know where or who might have old version 1.05 firmware for my Xantrex Xw6048. I would like to use it as AC coupling with solaredge inverter. I am at version 1.07 but cannot see it on my SCP panel, although it is available on the combox but does not do anything when I enable the ac coupling setting on combox.
Thank you in advance
Explain more please. Have you tried a DC reset? Just an FYI, build 1.07 is needed on xw for combox to work correctly with XW6048. Going backwards in firmware is not a good idea, why do you think it is please?
You probably know that xw6048 and combox are out of support. They are from an era when AC coupling was not implemented well or only worked with compatible makes of inverters.
Even now, AC coupling is a source of headaches or worse in small systems. Also hard to see what is happening with sources and devices that are not all on the same network.
AC coupling is best in a microgrid of homes (or a resort) with many sources of solar, and managed or monitored by a skilled user. Definitely not set it and forget it."we go where power lines don't" Sierra Nevada mountain area
I recently bought a solaredge HD inverter and want to use my XW6048 as backup using my 460ah batteries as backup for my home. I did read that ac coupling was introduced with 1.05, so i'm wondering if it was disabled on 1.07. I did try to change setting in standby mode using the combox, as the setting is on there but not my SCP unit.
When you mention DC reset? do you mean power off completely?
I was also wondering if the SCP firmware is not compatibleV02.04.00-0001
Thank you much Dave -
Maybe you need to update the combox firmware to see the new XW firmware ?
FW20180323-Conext-ComBox-Firmware-Ver-3.08-BN874-150-0279-03-08
https://41j5tc3akbrn3uezx5av0jj1bgm-wpengine.netdna-ssl.com/wp-content/uploads/2018/04/FW20180323-Conext-ComBox-Firmware-Ver-3.08-BN874-150-0279-03-08.zip
So, yea firmware needs to be correct all around and going backwards on XW is definitely not correct.
Back in those days, the only grid inverters that were compatible, that I remember, were SMA and Xantrex. All of that changed in XW+ the new XWP. They work quite well now. You just need to be very careful with a small battery if you can make it shift frequency for charging.
Good Luck"we go where power lines don't" Sierra Nevada mountain area
Thank you Dave. I will give this firmware a try.
I'll update when test. -
Dave,
Looks like my combox is already at that level. Last week I did upgrade SCP and combox to what was on the Schneider website. Concern was, that maybe these firmwares don't work well with legacy XW6048.
Thank you again -
I know that they work just fine together with an SMA or Xantrex grid inverter. I really doubt they will work with what you have because there were many others that did not work in the 2010 era when people really started AC coupling en masse.
Ask Solaredge for guidance!"we go where power lines don't" Sierra Nevada mountain area
The real issue that I was trying to figure out is, why don't I have the ac coupling feature on my SCP?
I have it on the combox but seems to do nothing because if I change it on the combox, then reboot or next day go into settings, it's disabled.
Maybe the trick is to exchange the solaredge for Xantrex grid tie but really like the optimizer feature on solaredge.
Thanks -
I see your point. FYI on xw+ and xwp AC coupling is on by default these days. What happens when you go into 6048 advanced settings, then advanced features on SCP ?"we go where power lines don't" Sierra Nevada mountain area
The SCP will force the Xantrex 6048 into standby and only 4 settings are available
Remote power off
Power save
Sell delay 40s
Generator support plus.
Those are the only options under advance features thru SCP.
Regards, -
It looks like the SCP is good for firmware, is it 2.04 ?
So no faults or warnings logged and have you tested the frequency shift?
One way to do that, in ac coupling, if you have a lead acid battery, is set the eq voltage up to 62+ v. As you start increasing battery voltage the load frequency at the bottom of the inverter screen or on combox, should go up from 60.0 hz.
Below is a Schneider/AEE curtailment or ac coupling link. I am going to bail on this as you may be as far as you can go with the old 6048.
https://aeesolar.com/wp-content/uploads/2018/01/AC-Coupling-and-Frequency-Shifting-DC2018.pdf
Thank you for advice Dave. I know being old, not much support from Schneider.
- 232 Forum & Website
