Battery replacement quandaries.
softdown
Solar Expert Posts: 4,038 ✭✭✭✭
Not many will muscle through this, maybe three. Here goes:
Bunch of old batteries (think 8 years) that read approx. "54% good". I recently replaced two such 2011 batteries and one failed a month later - bad cell. So that was a pretty decent call. Replacing solar bank batteries is best done before failure.
Just replaced two more old batteries reading approx. "54% good" - made in 2012:
1) One for the generator - could be pretty important in a crunch.
2) One for truck that occasionally had a real hard time spinning a warm engine when starting. Figured it was the battery. It was not. The new battery also struggles on occasion with a warm engine. I changed the oil yesterday - it was due anyway.
Well money is tight - it usually is. Playing with the idea of returning both new battery purchases. The old batteries are testing better than they had before - probably because they are much warmer. Then again - "54% good" might last another year. But not much longer than that.
Battery replacement - pros and cons for sure. If we have a catastrophic economic failure - who knows what parts of the supply chain are effected. Hyper inflation is a possibility with all the fiat money being printed so freely.
Vehicle batteries lasting more than 5 years are rare, or way oversized. I'd get new, if you are concerned. If they were younger than 5 years, I'd try a desulfator on them for a couple days.
With so much less vehicle usage I've taken to putting a Battery Tender (Tm) on my Tacoma and Pilot...alternating between them. There's always BT's on my tractor, mower, generator and never any problems with starting or longevity. I thought, with all the computer driven doo dads on late model vehicles it would be wise to keep their batteries at full state of charge.
Ralph -
Keeping them charged is instrumental. Eight years is eight years no matter what we do. Would they last nine years? Probably. But what if it fails at a bad time or spot. Very old cells can go bad quite quickly.
