Battery bank - pico hydro - Help!
jamie2020
Registered Users Posts: 1 ✭
Hi, am from the remote Baelelea region of Malaita island in Solomon Islands. Am acquiring a pico hydro 3kW system (correcting for overall efficiency useful power at 2.4kW) to run a community primary school, rural clinic and about 60 households in 4 small rural villages, estimates at 600-700kWh/day consumption.
I need your help regarding building a battery bank especially to maintain clinic and frozen goods, assumption, two days of autonomy during maintenance of power stations and or necessary shutdowns during thunderstorms. Need to build a battery bank. What capacity should the battery bank be? How many 12V batteries would I need?
Many thanks,
Jamie
Many thanks,
Jamie
First question: How many freezers and how many refrigerators?
Second question: Rated power consumption for both of these.Island cottage solar system with approximately 2300 watts of panels, 1kw facing southeast 1.3kw facing southwest. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 32nd year. -
3kw for 60 houses and a school? Did i read that correctly ?2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
If your daily load is 600kwh, and your charger is 2.4kw, you need 250 hours in a day to supply that load ???
