How do you get LiFePO4 matched prismatic cells?
MontyYoung
Registered Users Posts: 12 ✭✭
I'm looking to get some CALB, SP, or winston 180AH cells for 4 4S batteries in parallel for a small 12V cabin setup, & I hear guys getting these well matched cells but how exactly? I also don't wan't a balancing BMS at all and prefer to manually balance. As I read some sources of info online, matched means AH capacities within under 1% of each other, isn't this asking too much?
Can I buy online from places like ev works & gwl & expect to get macthed cells? what about ebay or alibaba?
edit: I meant ev works, not ev power.
The better the matching, the less babysitting you do on the bank. And if you had a 300ah bank, and one cell was 20% low, you now have a 240ah bank. Or they may be only 5ah different. Your guess is as good as mine
Being like lot numbers would likely be the best, the capacity variables of 1% would be of little concern since when in operation they shouldn't be charged or disharged completely to to extend service life.
Typically 90 to 20% state of charge is recommended, once ballancing is performed by charging all cells in parallel to 3.650 V, the maximum thereafter would be limited to~3.500V per cell bulk for a short duration, <10 minutes, then float at ~ 3.375 V per cell by the charge controller. With these settings a BMS with ballancing would not be able to ballance due to the limited charge voltage, having a means of disconnecting the load automatically to prevent over discharge is more important, which is what a good BMS should do.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
MontyYoung said:I'm looking to get some CALB, SP, or winston 180AH cells for 4 4S batteries in parallel for a small 12V cabin setup, & I hear guys getting these well matched cells but how exactly? I also don't wan't a balancing BMS at all and prefer to manually balance. As I read some sources of info online, matched means AH capacities within under 1% of each other, isn't this asking too much?
edit: I meant ev works, not ev power.Who am I?→ Officially and exclusively authorized agent of CALB battery in China. CALB is a leading battery manufacturer in China and the leading brand in the world.Contact mail?→ Alvinsun02@hotmail.com or Alvin@fj-calb.com
- 231 Forum & Website
