Lithium batteries of unknown age?
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Was thinking a light weight 12 volt lithium power source would be useful in a light weight tear drop camper. Lithium batteries are expensive!
Found an affordable 105 aH unit at $400. Compared to a more typical new price of $900. But the seller has this to say about the age "Never used or installed but may have sat in inventory for extended period. May or may not show signs of shelf wear." https://www.ebay.com/itm/MH5RTD1A38G-Battery-105Ah-12v-Solar-RV-Wind-Marine-Deep-Cycle-Boat-Lift-Truck/372895510451?hash=item56d24defb3:g:FFUAAOSwFZdeCT8w#shpCntId
This thing could be a decade old. One would have to be a real gambler to invest in such an unknown.
Relax - I'm passing. They may, or may not, find a buyer.
EDIT: Date Code indicates 2018 mfg. date. Still passing - $463 with shipping. Shipping is $63.
How much does it likely weigh? I might buy if more prosperous. 2018 isn't bad at all.
softdown said:Was thinking a light weight 12 volt lithium power source would be useful in a light weight tear drop camper. Lithium batteries are expensive!
How much does it likely weigh? I might buy if more prosperous. 2018 isn't bad at all.This appears to be a low end lead-acid battery.MarcI always have more questions than answers. That's the nature of life. -
Shipping charge and dimensions tend to agree. Though we do have this tidbit:
"Chemical Composition: Lithium"
I asked them about the weight. Response may be interesting.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Sellers says "roughly 50-60 pounds". Light for a lead 106 aH battery. Very heavy for lithium - I would think.
Plus roughly 50-60 gives me 0% confidence. Who doesn't have a bathroom scale around? Why didn't the seller look at the Date Code? Some odd things.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
I have yet to see a Lithium battery with the Pb (lead) Recycle symbols on it. A 100 ah cheap standby AGM from China would weigh a touch over 60 lbs.
Yep - lead - weighs over 70 pounds in likelihood. Common size it turns out. https://www.sbb-battery.com/UploadFile/2015122116025722430.pdf
Seller shows voltage over 13 - he just charged it up. I told him it is lead.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
