Can't access store, was ok on weekend
Muskoka
Solar Expert Posts: 103 ✭✭
Trying to sign in to my store account and I continue to get the message below. It was ok on the weekend.
There has been an error processing your request
Exception printing is disabled by default for security reasons.
Error log record number: 159981630572
I just tried with my account (I have used very little, and probably 1+ years ago since last access)... Worked fine for me.
I will forward your issue to Rick Forbes @ NAWS for him to look at your account. He should reply to your email for the forum.
I;ve started getting lots of popups from NoScript regarding timeouts and crosssite attacks:
NoScript detected a potential Cross-Site Scripting attack
from [...] to https://forum.solar-electric.com.Suspicious data:
Error: Timeout! DOS attack attempt?,(URL) https://forum.solar-electric.com/discussion/355513/what-to-do-with-the-space-under-a-ground-mount-system#latest
and for every new thread I read.
Thanks Bill, I'm getting the same error when I try to browse items in the store, without attempting to sign in.
No problem signing into the store here.
Not device specific either, seeing the same with main computer, a laptop, and my phone. Just tried with my phone on data, instead of my home internet provider, and seeing the same. Phone data and home internet are different providers.
I'm not sure what is causing that error to occur. Everything is working fine on my end, so I can't reproduce the error. However, I did clean out the website's cached files which may help. Can you try logging in again and see if it works now?Website administrator for Northern Arizona Wind & Sun
I have tried our forum on my Windows 10 laptop, with NoScript. Both with the forum white listed, and unlisted... And no cross site warnings.There is a "sharethis.com" scripting add-on to our website--I assume this is for social media (Facebook and such), and I leave that unlisted/unapproved--I do not use Facebook, et. al.-BillNear San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset
Still seeing the same.
Muskoka,
Clear the browser cache and cookies on your side? (although, since you see this on multiple devices, I don't hold out much help for this solution)
Can you create a new login and see if that works for you? (Note: Rick is the software engineer, I am just trying to help with standard debugging tips).
I've tried that Bill, no difference, thanks for the suggestions.
I don't have a problem creating a new account, as long as my purchase history can be moved to the new account. Maybe Rick could advise on that. -
Unfortunately, we are not able to combine user accounts on the website. After looking at some of the error logs, I'm pretty sure this is a bug with the actual website code, which means I'll have to get our developers to take a look at it. As soon as I get any answers, I'll let you know.Website administrator for Northern Arizona Wind & Sun
Ok, thank you Rick.
Muskoka, my developers have found the problem. Something corrupted the account in the MySQL database. They're working on a way to fix it, now that they know what the problem is. I'll let you know as soon as they get it fixed.Website administrator for Northern Arizona Wind & Sun
Muskoka, the developers believe they have fixed the problem. Can you try logging into your account again and let me know if it works? Thanks!Website administrator for Northern Arizona Wind & Sun
Thanks Rick, sent a reply to your email.
Rick, per our correspondence today, thank you for seeing this through, and sorting it out.
Glen
