8-D Batterys?
2»
  • cowboy
    cowboy Registered Users Posts: 1
    I have 8d commercial truck batteries in my mic coach 6 of them and I run my air conditioning and heating  all appliances and have been using them for 4 years no problems I have 700 watts of solar panels and use a 2500 watt commercial inverter with mppt charge controllers
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,189 ✭✭✭✭
    edited March 2020 #33
    Cowboy, You are quoting a series of posts from 10 years ago. Things have actually not changed that much!
    Yes, 4D and 8D batteries are standard OEM in large coaches. With six 8Ds, you are likely runnig a Prevost class chassis. The term "truck batteries" along with the term "commercial" can be misleading to many people. If your coach builder knew what he was doing, you likely have deep cycle batteries.
    Marc
  • softdown
    softdown Solar Expert Posts: 3,972 ✭✭✭✭
    8D is just a general size template that is short and squat. Weight seems to run from ~120 lbs to 175 lbs. Solar applications require deep cycle batteries - which 8D may or may not be. A lot of Class A motorhomes use the 8D batteries to power the electronics. I can only hope they chose deep cycle 8Ds while suspecting that many did not.
    TIL that Sams sold 8Ds for $125 in 2010 - per this thread. They are now $200 vs $90 for Golf Cart batteries. The GC batteries are far better solar batteries of course.
    I would place a large bet that the vast majority of 8D batteries are simple 1400 CCA starter batteries designed for trucks. Just a very large battery really.
  • 706jim
    706jim Solar Expert Posts: 523 ✭✭✭✭
    Large and heavy. At least there are no golf cart batteries that I'm aware of intended to start engines.
  • Marc Kurth
    edited March 2020 #36
    softdown said:
    .................................................................................. A lot of Class A motorhomes use the 8D batteries to power the electronics. I can only hope they chose deep cycle 8Ds while suspecting that many did not.
    By far most high-end coaches (Prevost class) use 4D and 8D true deep cycle batteries. as few as 4, but 8 to 16 8Ds are not rare on the upper end. Tiffen has recently shifted to 300ah 6v "GC2 Tall" to take advantage of the smaller footprint in exchange for height in the "basement."  Those coaches are 14-16 kWh.
    Yes, of course, some motorhomes us 2-4 golf cart batteries. In general, the big guys have battery banks equal to smaller off-grid homes @ 12 kWH to 48 kWH.
    Marc
  • softdown
    I tend to suspect "profit maximization" to prevail. Pretty sure the deep cycle 8Ds costs more. The 1400 CCA starter batteries strike m as having more than their share of liquid - as opposed to lead. Could be wrong. Has happened before.
  • Marc Kurth
    Yes, of course, profit is why companies are in business. Yes, of course, true deep cycle batteries cost waaaay more - around $650. each for an 8D.
    It is important to understand that a few thousand dollars difference in battery cost is "chump change" on these rigs. Many people do not realize that the completed chassis with two "slide outs", no interior, no paint - just a shell - costs $980K. Then someone builds a motorcoach out of it, so $1.5 to million to $2.5 million is not rare. Heck, Michelins for the front tires alone cost around $1,000. each.
    Dave Angelini Solar Expert Posts: 7,041 ✭✭✭✭✭✭
    We had one break down at the local KOA. I got called and I must say he had more invested in his liquor cabinet than the battery bank. I saw some irish and scotch that had 24 year+ ages on them. He poured me home that night.
  • Marc Kurth
    Your new friend? :D
