IBM's new battery, we hope!
HmmmRalph Day said:Cost you? I took my Surrette's to the recyclers and got 30cents per pound for them. 2600 pounds.
Ralph is misreading. The Lithium type NMC cost $300 and they really could not tell me what they were going to do with it, other than take it off my truck...."we go where power lines don't" Sierra Nevada mountain area
Lead is very easy to recycle and reuse of course.
How/where did you get 30/pound? I was quoted .22 a few months ago. The price fluctuates but .30 seems extraordinary.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Nickel, manganese, and Cobalt as we were talking about..... Most common in cars as they offer the best power per weight, or use to recently.
35 cents for lead from the dealer I use, if you bought from them previously."we go where power lines don't" Sierra Nevada mountain area
30 cents from local large recycler. There were pallet loads of car batteries, one forklift battery...cracked cases and acid running all over the floor. I rented a special hand lift cart (wheels move up, wheels move down) to remove from the basement, then borrowed a friend's car moving float to transport 30 minutes away. Pallet forks borrowed for my tractor.
Scrap lead can be a moving target. My recycler currently pays me $.35 to $.39 per pound and they come and pick them up. This is based on 2,500 to 9,000 lbs. of clean AGMs that are not leaking and I have to palletize/stretch wrap them. The highest that I have seen is $.45 for a single 17,000 lb. lot - but that was two years ago.
Never understood wiling away hours on the net while abbreviating most anything possible. Especially C and F when talking temperature. Guess C and F are just that hard.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
We are here to help you understand
I am going outside to do some work in the place I love which is very understanding, I think!"we go where power lines don't" Sierra Nevada mountain area
AEDHWCFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
