California. Off grid. Module level rapid shut down
mosierpat
Registered Users Posts: 13 ✭✭
fire raptor and Tigo.Only ones. Anyone done it?
Guess I’ll be the first anyone want to help?
Historic restoration. I have a preliminary line drawing. And I’ve pulled permits before.I will come armed with substantial questions.
So far it seems like I’m in the rtfm catagory. Except I did rtfm and out back is out sourcing and midnight bird box is not there.
I run a classic 200 with outback vfx 3624 I think for a decade.
Don't put the panels on the roof, avoid all the rapid shutdown. Use pole mount, ground mount, or solar carport concept.Not sure how to get around the battery size cap though.Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I use the Schneider Electric RS solution and agree with Mike to avoid the roof. A reasonable inspector should not require RS if the habitable structure roof is not used. You may have to educate them. Good Luck
