Synchronising an inverter/charger with a generator
jeshuron
Registered Users Posts: 4 ✭
Can anyone provide a simple guide to synchronising a generator with a Xantrex inverter/charger? Any help would be appreciated.
What do you mean by "synchronization"? Modern AC inverter-chargers with AC1 and AC2 (genset) inputs generally take care of synchronization themselves (or "don't care"--Depends on the inverter's specifications/actual operating modes).
If you are asking about acceptable voltage and frequency ranges for the genset output vs the AC inverter-charger's input--That is something else.
You don't sync them, They work independent as I understand it. No increase in capacity, the AC run into the inverter/charger handles loads and the inverter/charger will charge the batteries or the inverter works independently to provide the power needs.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
It may also help to know details of the generator and inverter models.Off-grid.
My XW6048, syncs itself to the generator as it's qualifying it. When it's synced, it connects and passes power on thru to the loads, and if there is excess generator capacity, it is used to charge batteries. If a large load comes online, the battery charging cuts back, and if a really large load occurs, the inverter will kick on and assist the generator, and then go back to charging batteries.You have to program EVERYTHING properly for this to work . And it works wellWhen I am running the generator, I can tell by the loading sound, if it's charging, or assisting, and when the blow dryer shuts off !Powerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
