Total newb but want to buy a solar box
bennybolivar
Registered Users Posts: 1 ✭
Hey there, i'm totally fascinated about such solar boxes like this one --> https://solarcamp24.de/100W-Solarkoffer-MONO-WS100SKS
It's cheap, it's not to big and it would be enough for me. Does someone has experience regarding such a solar box? It would be for a camping trip into the woods entirely without electricity. I need it for charging my phone, led lights and stuff.
Thanks in advance
Thanks in advance
It's likely a bit big for backpacking, but might be good otherwise.
You'll want a small 12v battery (eg AGM powersports type, or lithium pack) and 5v or whatever adapters for devices to be charged.
I'm not a fan of clips to the battery and would probably replace with better connectors, but that's just me.Off-grid.
Publishing a link in English would be helpful when you're asking questions on an English language board. From what I can tell from the photos the unit is just a rack of panels. There does not appear to be a battery, charge controller, ect to go with it. So, what exactly is the "box"?
System 1) 15 Renogy 300w + 4 250W Astronergy panels, Midnight 200 CC, 8 Trojan L16 bat., Schneider XW6848 NA inverter, AC-Delco 6000w gen.System 2) 8 YingLi 250W panels, Midnight 200CC, three 8V Rolls batteries, Schneider Conext 4024 inverter (workshop) -
I think you would be happier with a USB power bank (battery) and USB lights, cell phone charging and stuff that runs on electric. Look for something in the 20,000 amphour size. It would give you many charges on most phones and you can find fans, lights, radios, mp3 players that run off a USB power supply. If you would like to add charging while you are camping look for a 5v USB output solar panel.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
There is an English tab that pops up, at least on my device.MichaelK said:Publishing a link in English would be helpful when you're asking questions on an English language board. From what I can tell from the photos the unit is just a rack of panels. There does not appear to be a battery, charge controller, ect to go with it. So, what exactly is the "box"?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Here is something similar for less money. https://www.amazon.com/dp/B074G1P2X5/ref=sspa_dk_detail_1?psc=1&pd_rd_i=B074G1P2X5&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFYSVpLUklZTjJWQUsmZW5jcnlwdGVkSWQ9QTAxMTk4NzExNUFZMEcxU0ZOS1dVJmVuY3J5cHRlZEFkSWQ9QTA2MTI0NTYzTTZEWVgyRkNTMldNJndpZGdldE5hbWU9c3BfZGV0YWlsJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== It has an attached PMW type controller and folds for transport.
Renogy makes a smaller 50 watt model that folds the panels into a protective plastic case. https://www.amazon.com/Renogy-Eclipse-Lightweight-Suitcase-Controller/dp/B07FW75XB6/ref=sr_1_10?crid=LS97LHAWLOLT&keywords=renogy+50+watt+solar+panel&qid=1574987323&s=lawn-garden&sprefix=Renogy+50,lawngarden,156&sr=1-10
But if all you're looking to do is charge a cell phone or a rechargeable light a 15 watt (or larger) foldable panel with USB outlets is sufficient. https://www.amazon.com/RAVPower-Charger-Waterproof-Foldable-Compatible/dp/B07RMDKK5B/ref=sr_1_7?keywords=15+watt+USB+solar&qid=1574986872&sr=8-7
48v Rolls 6CS 27P
- 230 Forum & Website
