Battery charging
If in full sun absorb set at 14.8 volts.
after 2 hours showing 1℅ 4 amps on 400 ah Batteries. Why would S.G be 1.250?
2kw array 6 345 q cells  make sky blue 60 cc
 6 230ah GC @36 volts
18 amp accusense charger. 3650 champion
  • mcgivor
    What is the fill SG from the manufacturer? Some use lower SG to extend lifespan at the expense of slightly lower capacity.
  • mountainman
    mountainman Registered Users Posts: 442 ✭✭
    Us battery states 1.270 minimum S.G.
  • mountainman
    Batteries are not using any water. Maybe I should try raising voltage?
  • mcgivor
    Are you using temperature compensation and are the batteries cold?
  • mountainman
    Yes I have temp compensation. Batteries are out side. Temps lately have been 35- 40 f at night. 60 f days. Daily useage ~15℅
  • Estragon
    Have you checked voltage in absorb at the battery?  At ~50°F, it should be higher than the 14.8v setting.
    Also, have you measured SG at 1.27 with this meter on these batteries previously?  My first meter measured consistently low.
  • mountainman
    If I'm away for a sunny weekend not running the inverter. SG goes up to 1.27.
     checking  the absorb  voltage on a 40f day
    ~14.9.
  • Estragon
    Assuming that's 14.9 at the battery, sounds about right.  If it's at the controller, I'd check at the battery as well.
    Are the batteries sort of fizzing a bit with a few "burps" near the end of absorb?
  • mountainman
    Yes on the battery. Ive looked inside the batteries and they are fizzing and occasionally they will burb. The part that puzzles me is not using water. I bought them July 1 of this year. In the summer daily  SG was good unless of course it was over cast.
  • Estragon
    My L16s hardly used any water at first.  IIRC, well under a gallon in the first 6mos.  At 5yrs, they're up to ~2-3gals/season.
    If they're bubbling, I wouldn't increase voltage.  Assuming the 1% / 4a read was net into the bank (ie not reduced by loads), I don't know why SG would be that low.
    Are the cells consistently 1.25?
    Could the meter be sticking?  Sometimes a bit of crud finds its way in, requiring pretty vigorous rinsing to clear.
  • mountainman
    Yes end absorb 4 amps 400 ah Batteries with no loads.
    Like I said if Im away a couple days not using any power.
    SG comes back to 1.270
  • mountainman
    My arrays are 380 on mppt range is 20-24 amps on ~70℅ soc. And 400 on pwm 22-24.5
