How to measure whole house load?
ligwyd
ligwyd Registered Users Posts: 217 ✭✭
I have been told that a device from Efergy is a cost effective way of measuring your total power consumption over a period of time for the purposes of sizing a system.
What is the consensus here for doing just that? Any recommendations? Have a generator running everything right now but would like to know how much power is actually being used to start accurately sizing a system build.'
  • icarus
    For under $100 you can buy a used utility meter, either pointer or digital, along with a meter base.  Wire it in, read the KWH.  Want to record genny & PV?  Wire two.  All pretty simple
    there are also CT metering schemes that would work as well, but probably not as inexpensive yet, but may be easier to install?
  • Marc Kurth
    Marc Kurth Solar Expert Posts: 1,191 ✭✭✭✭
    Tony, I agree - using Current Transformers will be waaaaaay easier to install. Get split core CT and the exposure to heavy power will be a few minutes.
    I just use the metering data provided by my local utility - including hourly.
  • mcgivor
    For ~$50 I used a power recorder to log energy useage over a month, this one is rated for 3750W which is greater than the output of my inverter so doing whole house loads were possible in my case.
    https://youtu.be/qZ5FoI6qoXI
    TED has been around for a long time... And they have different models that can measure more than one circuit (main, water heater, A/C, etc.).
    http://www.theenergydetective.com/
    Just of an example of what is out there...
  • icarus
    Mark,  do you have a brand/model you use?  Ihave a client that I need to do an analysis for with 15 water heaters and 15 clothes dryers.  The client has no idea of how much load these draw on a annual basis used seasonally.  As part of a broad audit I want to meter/log each device for a year.  I have not seen a CT system that is really affordable in quantity.  I have found some 240 vac pass through meters but that is a wiring issue, each one needs to be hard wired (and enclosed).  Failing that, I can buy cheap meter bases and cheap utilities meters for ~$35 USD for the pair.  That comes with an install headache and cost as well.  I might consider doing the water heaters one season, the dryers a second, so the hardware could be moved.
    Thanks,
