How to measure whole house load?
ligwyd
Registered Users Posts: 217 ✭✭
I have been told that a device from Efergy is a cost effective way of measuring your total power consumption over a period of time for the purposes of sizing a system.
What is the consensus here for doing just that? Any recommendations? Have a generator running everything right now but would like to know how much power is actually being used to start accurately sizing a system build.'
For under $100 you can buy a used utility meter, either pointer or digital, along with a meter base. Wire it in, read the KWH. Want to record genny & PV? Wire two. All pretty simple
there are also CT metering schemes that would work as well, but probably not as inexpensive yet, but may be easier to install?
Tony -
Tony, I agree - using Current Transformers will be waaaaaay easier to install. Get split core CT and the exposure to heavy power will be a few minutes.I just use the metering data provided by my local utility - including hourly.I always have more questions than answers. That's the nature of life.
For ~$50 I used a power recorder to log energy useage over a month, this one is rated for 3750W which is greater than the output of my inverter so doing whole house loads were possible in my case.
https://youtu.be/qZ5FoI6qoXI
TED has been around for a long time... And they have different models that can measure more than one circuit (main, water heater, A/C, etc.).
http://www.theenergydetective.com/
Just of an example of what is out there...
Mark, do you have a brand/model you use? Ihave a client that I need to do an analysis for with 15 water heaters and 15 clothes dryers. The client has no idea of how much load these draw on a annual basis used seasonally. As part of a broad audit I want to meter/log each device for a year. I have not seen a CT system that is really affordable in quantity. I have found some 240 vac pass through meters but that is a wiring issue, each one needs to be hard wired (and enclosed). Failing that, I can buy cheap meter bases and cheap utilities meters for ~$35 USD for the pair. That comes with an install headache and cost as well. I might consider doing the water heaters one season, the dryers a second, so the hardware could be moved.Marc Kurth said:Tony, I agree - using Current Transformers will be waaaaaay easier to install. Get split core CT and the exposure to heavy power will be a few minutes.I just use the metering data provided by my local utility - including hourly.
Thanks,
