Nissan leaf 48 v lithium battery packs
mosierpat
Registered Users Posts: 13 ✭✭
Yes....I am using ten (10) 48 Vdc packs....each pack has 7 modules in a 14s configuration each with their own BMS. There are 70 individual Nissan Leaf battery modules total. They are all connected in parallel through a Midnite Solar lithium battery combiner box. Each cell can be monitored via Bluetooth. They work great. I am just finishing the installation.mosierpat said:Pretty abundant on Ebay, anyone used these yet?
@mainecooncats
setup looks nice and clean. I am in the process of installing a similar setup but in a 7p6s (42 modules). Wouldn’t mind hearing the performance of your battery capacity once you are up and running.
Hey guys. Any updates on this? Super interested to hear how you guys faired on these.
I am using 63 packs running 14s for over a year now, they have been fantastic. No BMS yet, and they are all within 1/10th of a volt all the time. Using mine with Conext XW 6848 and two Conext MPPT60 charge controllers and 18 310w panels.
Can you please share your controller config. i have 15 in a 6s config, at this moment I'm trying to figure out the sweet spot.
I would appreciate so much your help.
