Ground mount solar panels
wellbuilt
Solar Expert Posts: 763 ✭✭✭✭
Hi all , I have a question about ground mounting some solar panels .
I have a leach field for my cabin roughly 40x 100 ‘ and I would like to mount a row of panels across the 40, end so 9 panels 3 strings of 3 or 12 panels 4 strings of 3 in picture frame configuration .
I really can’t dig footings in the leach field and keep the DEC happy but I can service mount the panels .
The question is what could I use for ballast , I know a lot of guys just make a wood frame but I’m looking for something more permanent.
I have 4 pieces 8x8wide flanged steal beams 8’ long 40lbs a foot 320lbs each .
Then I have 4 concrete 18x18 x36” concrete wall block @ 800 lbs each .
I can also get my hands on some 2x2x6 Mafia blocks that are used to make storage bins in supply yards that are about 2500lbs each .
I’m thinking about placing them @ 10' apart , I’m in a windy area but we don’t really get hurricanes
I would use sch 40 pipe bolted / welded to the block or steal . Thanks for the reply’s John
Out back flex power one with out back 3648 inverter fm80 charge controler flex net mate 16 gc215 battery’s 4425 Watts solar .
Building a space frame out of lesser gauge square steel is incredibly strong, mounted with tee feet embedded in concrete will provide sufficient ballast, a simple form made of 2 × 6" lumber could be made to float above grade with some rebar to prevent cracking. The most important thing to remember is cross bracing, strength is in triangulation, most tend to over build with large dimension lumber, but steel is far stronger if properly designed, it is however subject to corrosion, galvanized steel is particularly useful in such conditions, or a good primer and paint works well.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I have seen people pour concrete in large sono tubes on the surface, or into short culvert sections (or even wooden forms, as long as the mass is big enough to secure the panels from wind. Also I have seen people use “jersey barrier/no post” concrete abutments.
tony -
Another possibility might be helical anchors/piles like are sometimes used for decks. I'd be a bit worried about really heavy and non-permeable ballast on a septic field?Off-grid.
I like the suggestion of helical anchors especially the ones used to stabilize telephone & electrical poles. Should be able to locate the field lines by pushing small diameter steel rod in suspected area and if you hit the gravel bed for the sewer line move over and locate the next and so forth. Of course still depends on approval of building department.
Hi all , I’ve been cut off for a few days , I can’t singe in .
I’ve decided to go with 4 concrete blocks @ 3500lbs each I picked them up for free .
I’m going to set them in line 10 feet apart .The frame work will be made from 2” sch 40 I want to use iron ridge 1000 to mount my panels but I’m not sure it can span the 10'Out back flex power one vfx3648A 15 295 watt panel .Out back fx80 CC
16 GC 215 amp ah battery’s
9 295 watt panels for ground mount will be installed next year
- 234 Forum & Website
