Inverter ac output
Femijolaolu
Registered Users Posts: 3 ✭
I left my inverter connected to the ac power source overnight to charge my battery and supply power. Power from the ac dropped and went off and so did the inverter. In the morning, I tripped the inverter, it would not supply. The inverter only came on when the sun came up with the charger controller supplying power. Right now, the ac indicator light on the inverter (soccer power 2.5kva 24v) does not come on and the inverter does not output in ac mode. The body of the inverter also shocks. What happened and what can I do
What model of inverter is it ?
Any solutions please
There are many possibilities when connected to grid power especially if there is no surge protection, the grid could have failed due to lightning, even if far away, is that a possibility and do you have surge protection?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
If the body if the inverter is now live , you have a serious problem . What brand of inverter? Did the livening happen on its own accord or have you changed any conections ?2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
Once again...what brand/model inverter?
Soccer Power 2.5 kva 24V is what was stated in original post, seem like an inexpensive Asian brand.icarus said:Once again...what brand/model inverter?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
Sorry, never heard of that brand, and missed it in the OP as a result.
