Hey, Dave! Not about weeds
Along the same lines of the eclipse one can sign up for an e-mail of when the space station flies overhead. if you have not seen it, it is one of the nice things to see in the night sky. We have been watching it since I was a project engineer on one of the sub systems.
https://spotthestation.nasa.gov/
Mark,
Word of caution about outboards and sub freezing temps. Keep the lower unit of the outboard submerged and it won’t be damaged. Alternatively, it looks like you have a boat lift. Make sure the outboard is tilted completely down to drain or the water in it won’t drain. Tilted outboards hold water and will freeze and crack. I have to keep a boat in the water until the lake nearly freezes solid. Our bays an inlets freeze, but my island “Harbour” doesn’t until the rest of the lake freezes. This year we may seal up a month early with this cold snap, if we keep getting cold nights with no wind. Once it has sealed, it won’t reopen until May.
Tony -
I kinda wondered about outboards and freezing. Had to pull & winterize my (I/O) boat a few weeks ago and close up the cabin for freeze-up.
There's a little Lund and 9.9hp OB that came with the place. One of these years maybe I'll get around to seeing if I can get it running. My bay will be frozen over now, but lots of years I think it's open until near end of Nov.
Blackda3 said:Hi Marc - I also wanted to say thank you for the beautiful photos. I know the following is very much an "in the weeds" comment but I wanted to call to your attention that on 08-Apr-2024 you will be in the path of a total solar eclipse. I hope you get a chance to enjoy it.OH, Yes Sir - I do know and I am looking forward to the opportunity!I always have more questions than answers. That's the nature of life.
icarus said:Mark,
TonyTony,I appreciate the info. I always tilt my outboard "down" all of the way in order to relieve the hydraulic pressure on the trim/tilt actuator seals. This also drains the water at the same time.Plus, I never leave it tilted up in order to avoid crankcase oil (4 stroke) from seeping past the rings, into the the cylinders. Got that from my Yamaha manual.In fact, my motor only gets tilted up once per year when I pull the boat for maintenance. (I have my own launching ramp) It takes only 30-40 seconds for the lift to get the boat up high enough for the prop to be dry, while trimmed all the way down, so I just lift the boat out at the end of each boating day. We occasionally hit 12F to 14F here for a night or two (18F last night) but very, very rarely stay below freezing for a full 24 hours.I will be out boating in warm weather next week!MarcI always have more questions than answers. That's the nature of life. -
Dave Angelini said:Along the same lines of the eclipse one can sign up for an e-mail of when the space station flies overhead. if you have not seen it, it is one of the nice things to see in the night sky. We have been watching it since I was a project engineer on one of the sub systems.
https://spotthestation.nasa.gov/Great reminder - I keep forgetting to do that!I always have more questions than answers. That's the nature of life. -
I haven't seen any of Marc's pictures.
Ralph Day said:I haven't seen any of Marc's pictures.
Rick4480W PV, MNE175DR-TR, MN Classic 150, Outback Radian GS4048A, Mate3, 51.2V 360AH nominal LiFePO4, Kohler Pro 5.2E genset. -
I think that there was a misunderstanding when I said that this Thanksgiving would include Turkey. These two came strolling into my yard assuming that they were invited! Not what I generally think of when ordering Wild Turkey.I always have more questions than answers. That's the nature of life.
As Homer Simpson would say.....”rrrrrrrrr...tuuuuukeeeey!”
LOL I was surprised by their sudden appearance.
Lovely, I can see them. Around here they've become pests...farmers doing crop insurance claims due to their munching.
Around here, the coyotes, bobcats and feral hogs keep the wild turkey population under control.
- 224 Forum & Website
- 617 Discussion Forums/Café
