Small System Opinion
Crystal
Crystal Solar Expert Posts: 128 ✭✭✭
edited November 2019 in Solar Beginners Corner #1
I found this for sale locally. https://www.facebook.com/marketplace/item/895246220872763/
Wondering if it's a good deal. We only need to charge a few batteries to run a few led lights and charge a couple devices.
I know most charge control is optimal but will this be sufficient?
Also if I want to upgrade and get more panels will this sharp be easy to match?
TIA
    Batteries not included.   What would be suitable, a pair of 6v golf cart batteries (wired in series).
    The charge controller needs to be a MPPT style for best charging of a 12V battery
  • Crystal
    Right I was thinking the same thing on the controller. MPPT auto corrected to most lol
    Thanks!!
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,172 ✭✭✭✭✭
    edited November 2019 #4
    With a single 12 volt panel the charge controller in the listing is better suited than an MPPT controller.
    You should be able to find a 120 watt panel to pair with that one fairly easily. If you do add another panel then , while the included controller will still be fine, an MPPT controller will be applicable if you series wire the pair of panels for higher voltage.
  • mike_s
    mike_s Registered Users Posts: 167 ✭✭✭
    Sure, MPPT would be more efficient. But it would be cheaper, and provide more power, to simply add a second panel in parallel.
  • mountainman
    mountainman Registered Users Posts: 442 ✭✭
    With The 30 amp prostar a good quality controller it  would even take  a third panel in parelell.
    Imho 370 watts would be a better  match than 250 watts for 2 200 ah GC batteries.
     Unless it's a long distance 50 foot or more to the array
    I'd stick with the controller it comes with.
     2 more panels would give more amps and be cheaper than a quality mppt controller.
    2kw array 6 345 q cells  make sky blue 60 cc
     6 230ah GC @36 volts
    18 amp accusense charger. 3650 champion
  • Crystal
    Thanks for the suggestions. So do I have to get the same panel to be compatible?
  • littleharbor2
    Not necessarily, As long as the voltage is within10% of the original you'll be fine. Pretty much all 12 volt, 36 cell panels will work. In parallel the current will add.
  • Crystal
    So it's a Maximum 17.2 volts.
    My next question can I put a larger wattage panel with it? The sharp is 123watts and I'd like to get a 300watt to add to it.
    Does it have to poly or will mono work with it?
  • littleharbor2
    The Sharp 123 will work fine. Any 300 watt panel is too high of voltage to mix with the 36 cell, 12 volt panels.
