Solar Panel Setup for a Fahrenheat FUH54 240-volt Garage Heater, 2500-5000-watt
gwpguy
Registered Users Posts: 1 ✭
I am extremely new to the Solar energy technology. So excuse me in advance for my lack of knowledge.
I am considering buying this heater for my garage. I am contemplating using solar to help keep the energy costs down. I don't even know where to start. What size panels? Batteries? Inverter? This would not be on 24 x 7. Probably just on the weekend while I am in the garage and a few nights out of the week. Any insights you can give me would be greatly appreciated.
Here are the specs on the heater.
https://www.marleymep.com/system/files/node/file/field-file//5200-11195-000.pdf
How may panels are you thinking about buying?????? I consider that heater undesirable as it requires a fan. Best performance would be from baseboard heaters with natural convection. A guy on youtube has a liquid floor heating system for his garage using a hot water tank and pump. That would provide some storage for the weekend. If using an inverter, that is delusional. A pulsed DC system is the best for resistive heating. I heat all my hot water with PV solar which is now cheaper than direct solar. No one here has more experience heating with PV and given that all the electronics is custom it seems you will have little success with this idea.
gwpguy said:I am contemplating using solar to help keep the energy costs down.
You do realize it's almost always cheaper to save power than it is to generate it right?
So instead of buying that piece of crap electrical resistance heater, maybe put in a good mini split heat pump?
You get 3 or 4 times the heat for the same amount of electrical power used.Solar hybrid gasoline generator, 7kw gas, 180 watts of solar, Morningstar 15 amp MPPT, group 31 AGM, 900 watt kisae inverter.
In my opinion it is not a good idea. Powering FUH54 with solar power won't be effective as it is a powerful garage heater. You can get more info about it at Garageaxs
You might also consider a propane radiant heater
Solar power is not going to help much at nights. To offset the power you use, you could install a Grid-Inter-Tie system and unwind your meter daytime and use that to offset your bill.
And mini-split heat pumps and propane heaters are good too
X2 on the mini split. Running a 2-5 kw resistance heater from PV is crazy when you can get more heat (net) by a factor of ~3 from a heat pump (more depending on temp).
Battery based solar is going to come at twice the cost and half the efficiency of grid tie (maybe more than twice the cost as grid tied PV has gotten so cheap). If you have the grid, go grid tie to “save energy”, couple that with heat pump and you are no track. Failing that, consider a propane or nat. Gas heater with a blower. A radiant propane or nat gas just for doing shop work might be the best plan.
tony -
My suggestion is a forced air propane heater for your garage. Fast and will work at night or when cloudy.
Plus you can stand under the heated airstream and pretend you are in Hawaii.
Others here may suggest a radiant propane heater which is also a good choice.
Even with panels costing less than $1/watt, your cash outlay will be a lot less with propane.Island cottage solar system with appriximately 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing due south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter which has performed flawlessly since 1994. Outback Flexmax 80 MPPT charge controller four 467A-h AGM batteries. Insignia 11.5 cubic foot electric fridge 1/4hp GSW piston pump. My 31st year.
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
