Battery Replacement Time
verdigo
Solar Expert Posts: 428 ✭✭
Hello everyone. It's been a while since I have been on the forum more than occasionally so my knowledge has suffered. I have been running my 16 GC2 Interstate batteries since 2014. They probably would have made it a couple more years but I should have replaced the cell caps and provided a cooler environment for them. My question is should I just replace them or is there a better cheaper technology available than Lead/Acid golf cart batteries. As for the overheating I plan to move them outside my shed. Gets pretty hot in there even though it's pretty well ventilated. Thanks
Dennis
Dennis
Really depends on temperature extremes, maximum and minimum, a little elaboration would be helpful.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
I am in Kentucky. I have a boiler type thermometer with a 6" probe that I place between batteries and have seen temperatures in the 130 -140 range. We rarely see ambient temps below zero but it does happen. New batteries will be outside in the shade with more space between them for better ventilation. Thanks.
Operating lead acid at those high temperatures would definitely need temperature compensation, moving outside may help in the upper ranges but temperature compensation would be beneficial in lower temperatures as well .
Let us know if temperature compensation is used.
5 years is a great long life for golf cart batteries. I'd do nothing different, and just replace them.
And reduce the battery temperatures (better ventilation, move out of sun/window/cover window in room, etc.).
More or less, for ever 10C (18F) over 25C (75F), your battery life (storage/float) is cut by ~1/2...
140F-75F = 65F
65F/18F = 3.61
2^3.61 = 12.2
1/12.2 = 0.08 battery life (1/10th of life stored at 140F vs if stored at 75F)
Generally, I would assume that your batteries are not always that hot (not summer)... In any case, 5 years is not bad life for "generic" golf cart batteries.
May or may not be an issue, but worth noting apparent capacity is reduced in cold temps.
Mine run around 2/3 rated capacity at ~0°F. Insulating the crawlspace they're in helped alot to moderate extreme temps (ambient outside ~ +100°F down to -45°, now ~ +65 to +5°F with insulation).Off-grid.
