Controller
yeoman
Registered Users Posts: 4 ✭
I have a new 5-45w controller. If I connect a known to be good 12v 7ah battery to the controller input side, the yellow charging light blinks, however, I get 0 voltage reading on the output side. Same when I connect my 20w panel to the controller. Panel is putting out 15-17v depending on sun angle, yellow charging light blinks, but 0 on output side of controller. Is this normal?
You should always connect a battery on the output side of a controller first, let it boot up fully, and only then put pv voltage on the input side. I wouldn't put a battery on the input side.
Pv voltage on the input side first can make the controller boot in unexpected ways. Also, the controller likely has a low battery cutoff voltage to protect itself, so with 0v on output terminals it's likely in LBCO.Off-grid.
I see. So if I first connect a battery to the controller output side, then panel to input side, should I expect a reading above say 13v at the battery? I was getting readings around 13.7 with this setup before corrosion ruined the previous identical controller.
The voltage at the battery will depend on its state of charge. For example, at rest, a 50% SOC lead acid battery will have a resting voltage of ~12.1v. When charging, this voltage will slowly rise until set absorb voltage (eg 14.x) is reached, about 85% SOC. When absorb is completed, likely from a timer (~2-3hrs) expiring, it should go to set float voltage (13.x) for as long as there's sun on the panels.Off-grid.
Thanks, With 24 12 volt batteries in my life I'm pretty familiar with SOC. I'm just trying to prove the panel is functioning through the controller.
If you have a DC amp meter you should see ~1a current flowing to the battery when the controller starts bulk charging?Off-grid.
I have a multimeter so I can see if that works if the sun ever comes back out. Thanks
Longer term, you may want to look at a DC current clamp DMM (digital multimeter). Makes it dead easy to measure current, debug systems, understand what is happening (no disconnecting of cables, won't blow a meter fuse, much safer, etc.)... A couple of links to start with:
https://www.amazon.com/gp/product/B019CY4FB4 ($100 medium price)
https://www.amazon.com/gp/product/B07546L9RT ($50 "good enough")
Note, there are AC only clamp DMMs, and AC+DC current clamp meters. Both are fine meters, but for our needs, the AC+DC current clamp DMMs are what work best.
Clamp meters are not very good at fine, small measurements, interference and drift are usually more than the measurement <1A
Would measuring more precise than around 1A in a case like this be important?
Considering a 20w panel connected to a 12v battery isn't likely to produce much more than about 1amp, a +/-1a accuracy reading isn't too helpful.
Lots of multimeters can test ok in this amp range, but need to be properly set and put physically in the circuit.Off-grid.
Get a volt meter with sufficiently low voltage range and any section of the wiring will be a fairly accurate current shunt.
- 651 Solar Water Pumping
- 608 Discussion Forums/Café
