12V 100W panel to charge small USB battery bank?
otterslide
Registered Users, Users Awaiting Email Confirmation Posts: 1 ✭
Is it possible to hook up a 12V 100W panel to charge a USB battery pack, like the Anker PowerCore+ 20100, or maybe two of them at a time?
I know it doesn't make sense to have 100W for this small battery bank, it's just a temporary use I'd like to have if possible until I can get some more expensive deep cycle batteries.
Basically, I want to gather some 100W panels and slowly build up a system, but as I gather the parts, get some use out of the panels. I can use the Anker Powercore to run a laptop, so that's pretty useful.
I know charge controllers require a battery.. so I'm not sure what kind of regulator may be out there for providing USB power output? The PowerCore needs 10 hours at 2A to charge completely.. I think 5Vx2A = 10 watts is all it needs really?
The small foldable solar panels have USB outputs on them, so I basically need some circuit like that, which can take 12V and turn it into a regulated 5V.
There are charge controllers that have USB outlets, you would however still need a 12V battery to power the controller, this would allow the hours needed as time would be powered bu the 12V battery after the sun can no longer support the load.
https://www.amazon.com/Controller-Battery-Intelligent-Regulator-Adjustable/dp/B072MMDY4F
A lot of the Anker 12 VDC USB "cigarett" USB power converters are rated to run at 24 VDC... I have used quite a few on 12 volt cars without problems, trying one on a "12 volt panel" (really around Voc~22 VDC/Vmp~18 volts)--I would give one a shot (no particular reason I picked this one--Other than the 24 volt support and USB C support):
https://www.amazon.com/Anker-Charger-Compact-Delivery-PowerDrive/dp/B07GZ78R6D-BillPowerDrive PD 2 is designed to charge phones and tablets. To charge laptops like MacBook and Huawei Matebook at full speed, you will need a charger with at least 30W output.
At a Glance Input: 12V / 24V ⎓ 4A; USB-C Output: 5V ⎓ 3A / 9V ⎓ 2A ; USB-A Output: 5V ⎓ 2.4A (max.). Dimensions: 35.7 × 35.7 × 68.6 mm / 1.41 × 1.41 × 2.70 in; Weight: 35 g / 1.23 oz
If you are cheap and a 'do it your selfer', you might search for <usb solar regulator> on ebay for a nice compact unit that will work from 6v - 20 volts. I bought 2 different and used them with a 30 watt, 6v, solar shingle, just a trial, and never tried with a 12volt nominal panel. About $1.50 and 3 weeks, can be had from US suppliers faster for about double.
I saw this while looking for a similar produce on Amazon, a couple bucks and no soldering!;
https://www.amazon.com/6V-40V-Step-Down-Voltage-Stabilized-Module/dp/B07XNNMFG2/ref=sr_1_4
To select a suitable charge controller you simply take the rated output of the panel and divide by the nominal voltage of the battery. So 100W / 12V = 8.33 Amps. Therefore a 10A solar charge controller will do the job and will typically have a power range up to 130W for 12V system.
onvert 12v to 5v using Zener Diode! check this video: https://www.youtube.com/watch?v=7SvSLPW3NJc
- 230 Forum & Website
