Adding to system question
hillside
Registered Users Posts: 148 ✭✭
That's what we do, right? Add to our system?
So after no response to my last questions--(I don't blame anyone; I'm hopeless, I know )
I have 3 panels ready to add to my basic system. With these 4 L16 batteries, I've been told here that I need in the range of 1300-1400Watts, (Currently at 1000W)
The 4th panel I was going to buy is not available, so with 3 good panels (235W) should I wire them in series or parallel?
I will use a Steca 30Amp PWM controller. Unless advised otherwise, of course. (But it's on the shelf of slightly used parts.)
8- 235Watt panels, 2 strings in series/parallel, 4L16 Deka 6Volt, 370AH FLA. batteries, 3000W Cotek pure sine inverter, SRNE ML2440 40Amp Controller & 40 Amp Renogy controller, 24 Volt system.
5 stand alone PV arrays; 12V gate opener, 24V Dankoff rain water pumping system, 12V Shurflo rain water garden pumping, 12V bathroom LED lighting and fan.
4- 450 Watt panels with 4 L16 6 volt batts./ 2-Renogy Tracer 40 Amp controllers/ Xantrex 1800W PSW Inverter.
Honda EU3000W generator for backup.
235 watt panels are 60 cell 20 volt nominal panels. You need an MPPT controller to properly use them. You haven't mentioned your system's voltage. What is it?
Yea... As LH2 says, we really need details. Many (most/all?) 235 Watt panels are Vmp~30 volts, although, you may have some ~36 volt panels too (not 20 volt--typo I think).
For a PWM controller on a 24 volt battery bank, you need a Vmp~36 Volt panels (72 cell) to have high enough voltage to reliably/quickly recharge your battery bank.
In very hot/sunny weather, you can get a Vmp drop to 80% of STC ratings (rough numbers)-- 80% of Vmp-std 30 volts is 24 volts... And you really need >30 volts to charge a 24 volt lead acid battery bank.
Note that Vmp curves are relatively rounded... So, if your battery bank is at 25 volts, you will still get some charging current... But we want to do this right. Details matter.
The 4 panels now show (at peak sun) 65.7 volts at the controller (from the panels) and they are in series/parallel.I've seen a high of 29V on the controller but that was only once, while most peak readings show 28V.Someone here suggested adding another string with it's own separate controller to boost the wattage for these batteries. So this would not be connected to the first array except to feed more to the batteries. (Correct?)I'd rather do that than scrap the new SRNE 40A controller I have now as it wouldn't take the wattage/amps.If needed I'll buy another mppt controller.The panels I 'd like to add are 3 Hanwha 235, Vmp 30.1, Voc 36.8, Imp 7.81 and 1Thanks8- 235Watt panels, 2 strings in series/parallel, 4L16 Deka 6Volt, 370AH FLA. batteries, 3000W Cotek pure sine inverter, SRNE ML2440 40Amp Controller & 40 Amp Renogy controller, 24 Volt system.5 stand alone PV arrays; 12V gate opener, 24V Dankoff rain water pumping system, 12V Shurflo rain water garden pumping, 12V bathroom LED lighting and fan.
4- 450 Watt panels with 4 L16 6 volt batts./ 2-Renogy Tracer 40 Amp controllers/ Xantrex 1800W PSW Inverter.Honda EU3000W generator for backup. -
BB. said:Yea... As LH2 says, we really need details. Many (most/all?) 235 Watt panels are Vmp~30 volts, although, you may have some ~36 volt panels too (not 20 volt--typo I think).
Please give people enough information to answer you question, I'm pretty sure this is my 3rd time suggestion this to you! Perhaps the reason for;hillside said:So after no response to my last questions
Look around and see if you can find a good deal on some 72 cell panels, they would havea vmo high enough to be effectivly used on a 24 volt bank in parrallel, so long as thee isn't a long distance to the charge controller/battery bank.
It's a 24 volt system Sorry I left that out/-corrected.Here is the current set-up: 4 250V panels.In some way, can I add 3 more 235W 24 V. panels to produce the needed wattage or amps to satisfy these large batteries?
250 WATT panels
If I recall, the suggestion was adding another string separate from the first with it's own controller...as it was stressed that I don't have enough wattage with the one array for these batts.
hillside said:In some way, can I add 3 more 235W 24 V. panels to produce the needed wattage or amps to satisfy these large batteries?
I'm sure the midnite Classic 250 would and there is sort of a deal on them unless sold out that were made for a special order/system and somehow Midnite has been left holding them. They are a stripped down version, but Midnite makes good stuff. The ones sold by private vendors don't have a warranty, but Midnite was sellinng some with the remainnder of the 5 years from manufacture warranty.
Discussion about them here;
http://midniteftp.com/forum/index.php?topic=4606.0
I think many/most of the less expensive MPPT type, like yours and the Renogy Rover, don't wat to see anny more thann 100 volts (VOC).
If you can find some 72 cell panels at reasonable cost, they could be used with a PWM charge controller and likely a lower overall cost.
FWIW - If the panels are the " Vmp 30.1, Voc 36.8, Imp 7.81" panels, they would not bbe considered 24 volt nominal panels. to be considered 24 volt nominal panels, the panel should produce 35 - 42 volts VMP.Home system 4000 watt (Evergreen) array standing, with 2 Midnite Classic Lites, Midnite E-panel, Magnum MS4024, Prosine 1800(now backup) and Exeltech 1100(former backup...lol), 660 ah 24v Forklift battery(now 10 years old). Off grid for 20 years (if I include 8 months on a bicycle).
If I go with the MidNite 250 should I wire the 3 in series or parallel?
hillside said:If I go with the MidNite 250 should I wire the 3 in series or parallel?
In series The Midnite Classic can handle 250 volts VOC (adjusted to your low temperature)
They have an online calculator to see what it can handle;
http://www.midnitesolar.com/sizingTool/
Thanks...got time for a stupid question?I can afford the MidNite Classic, or some other high end controller. But I recall reading (here, I think) that the controller does not step up charging but steps it down to keep the battery bank from overcharging.So, what does a $700-1,000 controller do that a $200. MPPT can't?8- 235Watt panels, 2 strings in series/parallel, 4L16 Deka 6Volt, 370AH FLA. batteries, 3000W Cotek pure sine inverter, SRNE ML2440 40Amp Controller & 40 Amp Renogy controller, 24 Volt system.5 stand alone PV arrays; 12V gate opener, 24V Dankoff rain water pumping system, 12V Shurflo rain water garden pumping, 12V bathroom LED lighting and fan.
The step up vs step down... We are talking about input voltage to the controller vs output voltage to the battery bank.
Solar charge controllers are, for the most part, buck mode switching power supplies. A "buck converter" can only take higher voltages and down convert them to lower voltages. And they tend to be the most efficient type of switching converter, and if you are, for example, setting up your array 10's to 100's of feet from the charge controller/battery shed, the higher voltage solar array cost much less in copper wire from the array to the battery shed (something like 1/8th the cost of copper wire if you double the array voltage).
https://en.wikipedia.org/wiki/Buck_converter
https://en.wikipedia.org/wiki/Boost_converter
https://en.wikipedia.org/wiki/Buck%E2%80%93boost_converter
There are boost converters (that raise voltage from input to output, and buck-boost converters that can take high/same/lower input voltages to output voltages). Just not usually done because there is not really much need (it is generally "free" to make a higher voltage solar array by wiring panels in series or series/parallel connections--Plus the savings using thinner copper wire).
There are a few boost solar charge controllers out there... Genasun is one that I am aware of:
https://sunforgellc.com/genasun/ (click on browse product)
https://genasun.eu/
Perfectly good solar charge controllers (as far as I know). Just tend to be smaller size (4-10 amps?) for portable applications.
In general, what makes MPPT charge controllers is the relatively large inductor (typically a toroid) inside the charge controller (cost of copper and cost to "wind" the inductor). Some MPPT charge controllers have relatively low input voltages (less than 100 VDC max input), and others are higher (140-150 VDC to 600 VDC). Higher input voltage controllers tend to cost more. And the typical higher end off grid MPPT controllers are around 60-90 amp output (typically 12-48 volt or a bit higher battery bank nominal voltage).
You can find very inexpensive MPPT charge controllers--Some are OK, others are not. And many of the "cheap" variety over the years have shown to be PWM type controllers with "MPPT" simply stamped on the outside of the case.
Generally, the higher cost MPPT charge controllers have more internal programming options, sometimes external outputs (for controller vent fans, optional loads, etc.)... And some have Internet Servers inside to allow partial or full control over the Internet.
The higher cost controllers have a generally good reputation (some folks do have issues). And the under $200 MPPT controllers--There are some out there that seem to be OK... Others not so good.
While our forum here is hosted and paid for by Northern Arizona Wind & Sun (NAWS or https://www.solar-electric.com/), "we" (NAWS) does not have any problem with us discussing any and all models and brands of solar related equipment. If you or others here have some particular brands/models you want to discuss--Go for it.
-Bill "not an employee or paid by NAWS volunteer moderator" B.Near San Francisco California: 3.5kWatt Grid Tied Solar power system+small backup genset -
BB. said:You can find very inexpensive MPPT charge controllers--Some are OK, others are not. And many of the "cheap" variety over the years have shown to be PWM type controllers with "MPPT" simply stamped on the outside of the case.
As to the cost difference, better features, wider specs, and more dependability (some of which comes from having wider specs/parameters). For example your 30 amp MPPT only accepts up to 100 volts VMP, Midnite makes one for around $300 that accepts up to 150 volts and can pretty much handle any over paneling (current wise)
I some of the features of the Midnite 250 have been removed so they could make it less expensively for the contract. It has the older version of the Graphics panel with out voice/speaker (which is removable and can also be remotely located like inside, for people like me who's system is installed in another shelter.) I'm not sure if it's disabled in that version, but the Classics can also send a small current out when the charge controller reaches a set point, like reaching 'float' it can send a current out to trigger a relay to start loads. Nice when you want to run a load and not draw down your battery, such as a water heater. In this manner you could run the water heater only off of available 'extra' power from your array and not from the battery bank.
If the charge controller can handle wider input and deliver wider output, then there should be less stress onn the system to deliver well within specs. This could often be seen in other electronics you may encounter, like inverters. If they have a narrow range of acceptable input voltage, then they have, in general, a cheaper build.
Wow, great answers, thank you guys.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
