How much does getting food from the fridge cost?
softdown
Solar Expert Posts: 3,812 ✭✭✭✭
So I woke up early to 50.1 volts. Not bad. Got a glass of milk and turned on the router/tv/laptop power circuit.
Then the fridge compressor turned on and ran for much longer than I expected. Voltage dropped to 49.7 before the fridge was satiated.
Voltage bounced back up 49.9 with the laptop battery recharged and a game of Monopoly finished.
Which left me wondering - What does a glass of cold milk really cost in battery wear and tear? When the panels are not producing energy of course...
How long did you leave the door open?
A quick open & close of the door?
Then the cooling cycle should not have been that much longer than normal,
because the "heat of capacity" of air is very low.
After one cycle, it should be back to normal
Did you hold the door open long enough to warm up the food?
Now the compressor has way more cooling to do.
It may take two longer cycles, or more.
The longer the door is open, the more the compressor will run ...
And possibly your fridge started its defrost cycle after you opened the door. Takes more power for a while when this happens.Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
The door is opened twice to get milk. Maybe for 2-4 seconds each time - wild guess there. It is likely that it coincided with a cycle that was due. I'd guess the fridge runs less than 10% of the time - but sometimes it runs for awhile. I think perceptions tend to be exaggerated upon initial wakening?
Been record breaking hot lately. The heat in the sunroom creeps a bit and the fridge runs a lot more when it is hot and sunny. The huge freezer could also have been running.
The forklift battery is doing OK now that panels are actually charging it. I expect to run the freezer from two 180 watt panels starting ~October. Technically - they are 175 since I "jumped the gun" buying my solar equipment. Builders have to be optimistic I think. But in this alpine desert at almost 8000' - I'm sure they produce more than most 250 watt panels. The valley offers great water and abundant sunshine and terrific distant scenery. Other than that? Eh.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Softdown,
I may have missed the post--What did you "fix" to get your system charging/operating properly again?
BB. said:Softdown,
-BillFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
softdown said:So I woke up early to 50.1 volts. Not bad. Got a glass of milk and turned on the router/tv/laptop power circuit.
Mike -
A few years ago I read a study comparing upright freezers with chest freezers.
They found that opereng the door briefly, on a full freezer had relatively little impact on power consumption. Adding room temperature food to the freezer did make a significant difference.
They also found that, under identical conditions, chest freezers a very slightly better efficiency than an upright. Not enough that it would be noticed in a typical application.
On a similar line. I have been shopping for a refrigerator for off grid. I am looking for something around 10cu.ft. and have been looking at Energy Star ratings to compare relative power consumption. The best I have found so far has an estimated power consumption of 328kwh a year.
Has anyone here found one with a lower energy star rating? -
I have an Insignia (Best Buy brand) 11.5 cubic foot fridge rated at 311Kwh/year. A slightly shallower version with the same compressor is 297Kwh/year at 9.9 cubic feet. And three months on a Killawatt meter registered slightly less than this advertised amount. I've seen this model advertised for as little as $400 CDN so should be that much cheaper in the US. Hope this helps.Island cottage solar system with 2500 watts of panels, 1kw facing southeast 1.3kw facing southwest 170watt ancient Arco's facing south. All panels in parallel for a 24 volt system. Trace DR1524 MSW inverter, Outback Flexmax 80 MPPT charge controller 8 Trojan L16's. Insignia 11.5 cubic foot electric fridge. My 30th year.
LG has a 450l inverter model uses 299 kw per year.that's 15 cubic foot . Had one for 2 years now , its great .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
petertearai said:LG has a 450l inverter model uses 299 kw per year.that's 15 cubic foot . Had one for 2 years now , its great .First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Crazy -seems to only be available in Australia from what I see. Pretty sure of that. Same with the 454L.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
Im in the little islands a bit south east of Australia. Think it was around $1200 on special .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home
https://www.lg.com/nz/fridges/lg-GB-450UPLX-450l-energy-efficient-fridge
I see it is discontinued , shame .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
petertearai said:https://www.lg.com/nz/fridges/lg-GB-450UPLX-450l-energy-efficient-fridge
I see it is discontinued , shame .First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
LG got slapped for lying about there energy ratings a while back
papab said:LG got slapped for lying about there energy ratings a while backFirst Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
I've recently got the LG 21.8 French Door unit (LFDS22520S) USA version. Love it. Crazy low consumption. 587 kWh /year and at my .09 for grid power, it will cost about $53 a year to operate.
MrM1 said:I've recently got the LG 21.8 French Door unit (LFDS22520S) USA version. Love it. Crazy low consumption. 587 kWh /year and at my .09 for grid power, it will cost about $53 a year to operate.
$50 is pocket change compared to off grid battery strings.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
For me, even off grid, the difference of 0.5 kWh per day would not be a huge deal breaker.
Well it might be for me unless the fridge was quite spacious. I grew up wanting a few things including a big fridge and freedom. Can't complain about my Samsung though - it might be 16.9ish going from old memories - which are surely off.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
LatinaSound said:Maybe it started its defrost cycle after you opened the door and this can consume more power.
It did seem to stay on for an unusually long period that morning though. It does seem to have defrost as I do not find frost on my frozen food. Seems to be a good fridge overall. It is Energy Star rated though not as good as several current offerings. Thinking it was made around 2008? Sat unused until ~2015 when I paid ~$400 for it. It was an $800 fridge in 2008.
Has a plastic milk and container holder that is prone to cracking though.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
It's an interesting question you've got there! The cost of getting food from the fridge can vary depending on factors like your solar setup and the energy efficiency of your appliances. When the fridge compressor kicks in, it does draw a significant amount of power.
If you're curious about the energy consumption, you might want to consider checking out products like barley powder. While it may not directly answer your question, incorporating energy-boosting supplements like this into your diet can help you stay energized while managing your power usage.
Wyantee said:It's an interesting question you've got there! The cost of getting food from the fridge can vary depending on factors like your solar setup and the energy efficiency of your appliances. When the fridge compressor kicks in, it does draw a significant amount of power.
Welcome aboard! -
Our LG 19 cu ft inverter french door fridge (bottom freezer with ice maker and cold water dispenser in door) use 365 kWhr/yr off grid.
No compressor startup surge either and it doesn't seem to care if power goes off and on throughout the day, just picks up gracefully and continues. Makes a lot of ice - we are very happy with it and have had it for about 4 yrs now.Offgrid in cloudy PNW
MacGyver'ed museum collection of panels, castoff batteries and generators - ready for state of art system install .... parade of surviving and dead generators: H650, Ryobi 900, Briggs and Scrap Iron 2000, H2200, H3000, Kubota 3500, Kubota 4500, Onan 7500
We have 2 Maytag chest freezers (mid sized) and a two year old Samsung 21.1, all energy star rated. I couldn't be happier with their lack of power draw. It brings a smile after having any of them plugged into a kill-a-watt for a week and doing some division. For us, even in the summer with temps in the 100s and no A/C, there isn't much change. But at time of the year we don't pay much attention to power demands. It's this time of the year right now that efficiency is so very much needed.Off Grid. Two systems: 1) 2925w panels, OB VFXR3648, FM80, FNDC, Victron BMV-712, Mate3s, 240 xformer, four SimpliPHI 3.8; 2) 780w, Morningstar 30a, Grundfos switch, controller and AC/DC pump, 8 T105. Honda EU7000is w/AGS. Champion 3100. HF 4550, Miller Bobcat.
