Five decades of frightful predictions...
softdown
Solar Expert Posts: 4,062 ✭✭✭✭
Well one of them is almost truish... Britain will be "Saudi" (like) by around 2024. Not exactly Siberia, but it starts with an 'S' so close enough for a local palm reader.REC TwinPeak 2 285W 3S-3P 2.6kW-STC / 1.9kW-NMOT Array / MN Solar Classic 150 / 2017 Conext SW 4024 Inverter latest firmware / OB PSX-240 Autotransfomer for load balancing / Trojan L16H-AC 435Ah bank 4S connected to Inverter with 7' of 4/0 cable / 24 volt system / Grid-Assist or Backup Solar Generator System Powering 3200Whs Daily / System went Online Oct 2017 / System, Pics and Discussion
I am not denying the heat has risen since the 70s when I was a little boy
I am not denying that CO2 plays a part.....but just a small part... man is not that big of a blip in history, and the planet on it's own has went through many climate changes, and we arent the only ones making CO2
heres where my theory comes in, because what I am going to say, the earth doesnt naturally do, but man does it....we have taken H2O and sealed it up into containers...not just bottled water either
soups, sports drinks, soda, antifreeze, BEER, wine..........even industrial cooling system use H2O in closed system chiller units
why is this important...because of the hydrologic cycle
_______________________________________________________________________________________________________
the hydrologic cycle is the exchange of of energy that influences climate
when water condenses, it releases energy and warms the environment
when water evaporates, it takes energy from the surrounding environment, thereby dropping the temperature
https://www.h2odistributors.com/pages/info/info-water-cycle.asp?fbclid=IwAR04GhTkh8vdN1N3wgiYCuLa2tCGVQZ6oPDx0FmveO-UOQY1xC3rdEPvTgc
I have written all my findings down on my facebook page here
https://www.facebook.com/chris.owens.18294/posts/10157601244834182
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw ) -
First point, well said, Second point, interesting.t00ls said:I am not denying the heat has risen since the 70s when I was a little boy
here is a good presentation of climate change and the deceit we have had played on us.... it does support your theory > CO2 is NOT responsible , it is the water that is the trigger... enjoy
- 234 Forum & Website
https://www.youtube.com/watch?v=1zrejG-WI3U
