Where are we with freeze alarms?
softdown
Solar Expert Posts: 3,821 ✭✭✭✭
Not looking for a phone call. Just a noise and the ability to set the temperature for the alarm. Seems that calling you when the temp hits 45F might be standard procedure with freeze alarms. Perhaps I am using the wrong search words.
Being a prepper I store food and drinks in several rooms. Nothing else matters if we don't have food. Glass bottles and aluminum cans can't handle a "hard freeze" of course. I'd guess that 24F may produce a hard enough freeze to fracture the glass and aluminum containers. That guess is as wild as it can be. Plastic is likely safe for quite awhile longer.
This area can easily see -30F. So a storage unit could witness a "hard freeze" with the right weather conditions.
I only heat 800 sq. ft. Or 10% of the entire building. The temperature of the rest varies depending on passive solar heating.
Generally the cooler the food and beverage the better. Just need to avoid the hard freeze.
I did some quick searches, and the only statement I could find was don't go below 40F.
The point at which items freeze is usually dependent on the amount of sugars and other ingredients in the specific item (for example, sea water freezes at ~-4C or 24.8F)... But It appears that the "raw" food only may go a couple degrees F below 32F before crystallization (freezing) begins.
Not exactly an answer to your canned good question, but I did run into this neat chart about the optimum storage conditions for a whole bunch of fruits and vegetables:
https://www.engineeringtoolbox.com/fruits-vegetables-storage-conditions-d_710.htmlProper storage conditions - temperature and humidity - are required to maximize storage life and maintain quality of harvested fruits and vegetables.
Fresh fruit need low temperature and high relative humidity to reduce the respiration and slow down the metabolic processes. The table below indicates optimal temperatures and moisture conditions for some common fruits and vegetables (here is an example of the first few entries).
Product Optimal Storage Temperature Chill Point Freezing Point Optimal Humidity Top Ice Accepted
1)Water Sprinkle Accepted
2)Ethylene Production Sensitive to Ethylene 3) Approximate Storage Life Comments (oF) (oC) (oF) (oC) (oF) % Apples 30-40 -1-4 29.3 90-95 No No High Yes 1-12 months Chill sensitive stored at 35-40 F (2-4 C) Apricots 31-32 -1-0 30.1 90-95 No No High Yes 1-3 weeks Artichokes 32-35 0-2 90-95 Yes Yes No No Artichokes, Jerusalem 31-32 0-2 28.0 90-95 No No No No 4-5 months
The major issue, of course, with canning/glass jars is the damage to the container once freezing begins (damage to container, failure of lid seal). And then the issue of changes to texture of what is frozen (some may be OK, others may turn to mush).
As Bill says, it depends on sugar content, etc, but freshwater ice is at minimum density near 0°C/32°F. It's most dense at~4°C, drops slightly as it cools to just above freezing, then drops a lot as it freezes (density drop = ~8-9% increase in volume IIRC). Once frozen, density increases (volume shrinks) a bit as temps get colder.
https://www.engineeringtoolbox.com/ice-thermal-properties-d_576.html
So it's not just temp, but also time that matters. Eventually water will "hard freeze" in freezing temps, doing so more quickly in lower temps.
If I wanted to be sure to avoid freezing, I'd keep the prepper supplies buried below the frost line with a rigid insulation access hatch. Ground temp around here is ~7°C year-round.Off-grid.
Estragon said:As Bill says, it depends on sugar content, etc, but freshwater ice is at minimum density near 0°C/32°F. It's most dense at~4°C, drops slightly as it cools to just above freezing, then drops a lot as it freezes (density drop = ~8-9% increase in volume IIRC). Once frozen, density increases (volume shrinks) a bit as temps get colder.
If I wanted to be sure to avoid freezing, I'd keep the prepper supplies buried below the frost line with a rigid insulation access hatch. Ground temp around here is ~7°C year-round.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
How about a cheap thermostat, wired to trigger an alarm instead of (or as well as) starting a furnace/heater?Off-grid.
I use a kerosene lantern in my greenhouse and plumbing sheds to keep frost out. Might work for food storage too.
Estragon said:How about a cheap thermostat, wired to trigger an alarm instead of (or as well as) starting a furnace/heater?First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries
mike95490 said:I use a kerosene lantern in my greenhouse and plumbing sheds to keep frost out. Might work for food storage too.
The plan is to either use small propane heaters or simply move the endangered liquids. I think it takes a really hard freeze to damage canned foods as a rule.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
softdown said:.........The plan is to either use small propane heaters.....I'd found the propane heaters were too hot, and pilot only, not warm enough, got tired of lugging propane tanks up and down frosted hills. Kero seems to be just right
This is what I came up with: https://www.ebay.com/itm/Wireless-Digital-2-Sensor-Refrigerator-Freezer-Thermometer-Alarm-Low-Temperature/352707984328?ssPageName=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Just started using it yesterday. Have not set the audible alarms so don't know the efficacy of those. So far, so good though they do not transmit through several walls involving steel and ~60 feet - no surprise there.First Bank:16 180 watt Grape Solar with FM80 controller and 3648 Inverter....Fullriver 8D AGM solar batteries. Second Bank/MacGyver Special: 10 165(?) watt BP Solar with Renogy MPPT 40A controller/ and Xantrex C-35 PWM controller/ and Morningstar PWM controller...Cotek 24V PSW inverter....forklift and diesel locomotive batteries -
Looks like it should do the trick.
I used some similar ones, but had to stop as the rf signals were triggering some remote controlled lights on or off, apparently at random.Off-grid.
- 626 Discussion Forums/Café
