how do i determine the number of coil winding/size in a axial flux generator ?
Keji
Registered Users Posts: 3 ✭
i am building a axial flux wind turbine, watched a few yt video and read some articles. i have built a small one, now want to move onto a bigger one.
but i couldn't find any information on how to calculate the size of coils for the required power output.
example i want to make a 48v 10kw generator, how would i calculate, how many turns is required, the wire thickness, how many coils per phase.
can someone please explaining the process in determining all this
Perhaps one or more of these links can help (we are not a bit DIY wind forum):
www.otherpower.com (good forum for DIY Wind Power)
Hugh Piggott - Scoraig Wind Electric site for tons of info (from mike90045)
Scoraig Wind "Recipe Book" for DYI Turbines (from Chris Olson... From his 4/11/2013 post)
www.greenpowertalk.org (added from "russ"--Like here but more wind/less solar)
10KW is a pretty large machine, but maybe you are not expecting 10kw worth of wind? When you do get the wind, you will need a huge dump load for that.
BB. said:Perhaps one or more of these links can help (we are not a bit DIY wind forum):
i had a look at them they all seem good, otherwind.com being the best but i cannot register as it would not allow me to register, would you have any idea about that, thanksmike95490 said:10KW is a pretty large machine, but maybe you are not expecting 10kw worth of wind? When you do get the wind, you will need a huge dump load for that.
the 10kw was used as a example (but i am heading in that direction) as i want to do the calculations for myself, every article i came across just gives me the number of turns for a 48/12v system and the wire size to use, with no explanation. -
I have never used/communicated with the Otherpower forum... Just try the registration link/process. Sometimes, it may take a day or two for some forums if they require a moderator to approve the application:
https://www.fieldlines.com/?action=register
- 654 Solar Water Pumping
- 619 Discussion Forums/Café
