Xantrex 4024 and Generator
johnny84
Registered Users Posts: 7 ✭✭
Hello,
I recently sent my Kubota 6500 in for service and bought a small inverter type generator as a standby. The Xantrex didn't like the new generator ( I read that Xantrex and inverter gens don't mix well ). I returned the gen and picked up a firman 7552, rated at 7500 running watts. Well, I could hear the ac2 relay kicking on and off.
I never had this issue before. Well, I brought back the Kubota, hooked her up and now I'm having the same relay switching problem.
No fault codes, I cleaned the contacts on the relay as best I could with emery cloth.
The new generator was reading 63 hertz. Did some thing get fried by the small generator?
Any suggestions would be most appreciated, thanks.
40 years, I was solar/off grid before solar was cool
johnny84 said:.......
Any suggestions would be most appreciated, thanks.Emery cloth is absolutely the wrong thing to clean plated contacts with. I'm really surprised a tech told you to do that. The striker strip of a match book is the traditional cleaner, but I usually just use a sheet of folded paper with 90% alcohol on it.Suggestion - plan on replacing the relay when the contacts weld closedPowerfab top of pole PV mount | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Oops. I read it while trolling this forum. Guess I know better now and thanks for the info. Any ideas on my situation? Besides, if they end up welding closed, I'd definably figure to replace them, that's an easy one to figure.40 years, I was solar/off grid before solar was cool
wow, mike95490, I'm #8373? cool, and thanks again. I did figure out the problem. I'll let you know if/when my contacts weld, crossing my fingers!40 years, I was solar/off grid before solar was cool
- 230 Forum & Website
