Where is that bloody low voltage alarm on this old inverter?
CrazyKGB
Registered Users Posts: 2 ✭
I picked up this old marine inverter and opened it up to remove low voltage alarm but didn't find the usual black barrel with the hole in the middle. Can some one help me and point to what to pull out to turn off the annoying beeping sound? Thank you.
Please see pictures
https://imgur.com/og7wN2u
https://imgur.com/g2BEIuW
https://imgur.com/kTViohT
Please see pictures
1) have mercy on us in the boondocks when you upload a multi MB image, you could at least crop it and spare us 8 minutes of loading time. kTViohT never finished loading.My bet is that it's on the panel sharing the end with the power outlet and phone jack and the multi-pin connector, it will be on that board facing the outside world.
You have me curious why the low voltage alarm keeps going off. What voltage is the alarm set for?MarcI always have more questions than answers. That's the nature of life.
The warning beeper is there for a reason, either the voltage is too low due to loads being too large for the battery, or the battery voltage is low due to being depleted or both. Sure it may be annoying but its trying to tell you something which needs to be addressed, I'm sure pilots find the terrain warning system annoying at times but it can be helpful in avoiding catastrophic outcomes.
Let us not forget that inverters are constant wattage devices. As the input voltage drops, the current draw increases.I begin to wonder if the original post was done tongue-in-cheek.I always have more questions than answers. That's the nature of life.
That warning is at a pretty low voltage. It is there not to protect the battery, but the inverter. Many are set to turn off at 10.5V which just happens to be near the 10V required to drive the FET into saturation for lowest heating. I believe people should be allowed to do what they want. If the inverter has an on/off switch (not a push button) one side of the switch is always 12V and the other side powers the inverter control electronics which is only about 200ma. Just buy a small boost converter and set it to supply 13V (switch always off), Then you can drive the inverter down to about 8V if you want.. It is your decision.
NANOcontrol said:That warning is at a pretty low voltage. It is there not to protect the battery, but the inverter. Many are set to turn off at 10.5V which just happens to be near the 10V required to drive the FET into saturation for lowest heating. I believe people should be allowed to do what they want. If the inverter has an on/off switch (not a push button) one side of the switch is always 12V and the other side powers the inverter control electronics which is only about 200ma. Just buy a small boost converter and set it to supply 13V (switch always off), Then you can drive the inverter down to about 8V if you want.. It is your decision.Nifty theory, but a very poor idea in the real world. Consider that:-12v batteries are "dead" at 10.5V under load. At this point, you have removed all of the rated capacity. Going lower is akin to slamming your engine past redline on your tach and holding it there. Even true deep cycle batteries rated to go to "0%" will sustain damage.-A little 1200 watt inverter (for example) that draws 110 amps at 12v, will attempt to draw draw over 160 amps at 8V with the same load. Sure, if that's what a person wants to do.....Marc
...and absent a lbco, the inverter would draw current on a decreasing voltage / increasing current curve until voltage is near zero, or current melts something.Off-grid.
Guys, its making same noise because it thinks it overheating. The fan was broken and I use "redneck fan" from another plug before I get one from aliexpress and put it in.
- 231 Forum & Website
