MT50 question
celticanuk
celticanuk Registered Users Posts: 2
Hi apologies for my ignorance but I'm after some advice about the MT50 please. I'm hoping this is normal operation and I'm worrying about nothing. The little arrows from the panel to the battery (charge display?) have stopped since plugging the van into mains at a camp site a few days ago. I can't seem to fine any info on normal operation. Can anyone advise?
  • mcgivor
    There is no load on thr battery, 12.7V represents a fully charged 12V battery at rest, try applying a load and see what  happens, as the voltage drops the PV should begin charging.
    Assumption. Loads are taken from the load terminals and the smiley face says everything is good.
  • celticanuk
    Thanks mcgivor, I was hoping that was the case but wanted to make sure. Many thanks :)
  • mcgivor
    Is the controller a MPPT or PWM, if MPPT the input voltage may be too low to provide any meaningful charging. Just an afterthought.
  • mountainman
    mountainman Registered Users Posts: 442 ✭✭
    If the battery is full shouldn't  the  pv show close to voc.
    2kw array 6 345 q cells  make sky blue 60 cc
     6 230ah GC @36 volts
    18 amp accusense charger. 3650 champion
  • littleharbor2
    littleharbor2 Solar Expert Posts: 2,115 ✭✭✭✭✭
    edited August 2019 #6
    According to the battery graphic the battery isn't much more than 1/2 full. Interesting... Also the arrows  are representing charging from the PV. No arrows, no charging.
  • mountainman
    edited August 2019 #7
    @littleharbor2 thats how my mt 50 shows the battery as not full @12.7 . It only shows full when changing at 14+ volts??. Are you seeing the arrow that indicates charging? Because I can't.
  • littleharbor2
    What I'm saying is if there's no arrow flashing there's no charging.
    12.7 is a nearly full battery without any loads or charging which is what your MT50 is showing.
    The voltage and the battery graphic aren't in agreement.
  • Estragon
    Maybe a silly question, but is the van now parked in any sort of shade at the new campsite?
  • spacebass
    spacebass Registered Users Posts: 87 ✭✭
    edited August 2019 #10
    The battery graphic is not regarded as very accurate.like it will go from full to half in one go.
