Equalizing
mountainman
Registered Users Posts: 442 ✭✭
PWM controller? Maybe. Being able to re-aim the panel during the EQ to keep it perpendicular to the sun might help, assuming the EQ could take a few hours.Off-grid.
Pole mount fully adjustable. Why the question pwm?2kw array 6 345 q cells make sky blue 60 cc
6 230ah GC @36 volts
18 amp accusense charger. 3650 champion -
Might work as well (or not) on mppt controller, but was thinking the difference between EQ ~15.5 and Vmp (~18v?) might not be enough overhead voltage (~16% vs 20-30% usually recommended).
Pwm just passes pv voltage through in bursts.
Mppt are also more or less pwm in absorb and EQ, but I don't know what (if any) effects buck circuits in mppt controllers have in absorb/EQ.Off-grid.
My pwm is not settable it's eq voltage is 14.8?? So I'm be using mppt.
My panel vmp is 19v. Still on the low end as far as overhead ~22℅
Assuming I can get 5 1/2 amps at 15.5 for 5 or 6 hrs.
Even if it took more than 1 day. Would 2.5℅ of capacity be high enough.2kw array 6 345 q cells make sky blue 60 cc
mountainman said:Is it possible to eq a 208 ah @12 Battery
With a single 100 watt panel? 15.5 at 5.4 amps.~2.5-2.6℅
Eventually if left long enough the voltage will increase to EQ levels, I have a 20W panel connected directly to a 45Ah battery so ~2.5% charge rate after 2 weeks of full tropical sun it reached 15.4V without loads, it was near full charge to begin with, the battery is used for an electric fence charger.1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
- 234 Forum & Website
