Help me choose a linear actuator
Kapitonov
Registered Users, Users Awaiting Email Confirmation Posts: 2 ✭
Hi! I want to put myself a linear actuator on the sliding gate to the cottage. I looked in the internet, there are a lot of offers and the prices are very different. Maybe there are people here who understand this and can advise me what type of actuator is better, manufacturer and where to buy? I will be very grateful.
I still stuck with this problem. Can't decide which is better. Any help?
How large is the gate ?1500W, 6× Schutten 250W Poly panels , Schneider MPPT 60 150 CC, Schneider SW 2524 inverter, 400Ah LFP 24V nominal battery with Battery Bodyguard BMS
For any distance over a couple feet, Which it sounds like you have with a sliding gate you might look into chain drive openers.
12 panels 6 series 2 parallel 2100 watts, 1 XW60-150 CC, 16 trojan 6V batteries 8 series 2 parallel 450 Ah, 1 XW 6848 pro, 1 5500 watt champion inverter generator( I know...I need a 12Kw )
I used a garage door opener (chain drive) to open a sliding gate many years ago...
- 228 Forum & Website
- 618 Discussion Forums/Café
